- Mar 30, 2015
What grit do you sharpen to? Are you leaving a wire-edge that is folding over after the first few cuts? Lots of great advice in the Maintenance Sub-forum for getting the most out of your edge.
I have a CalyIII in ZDP-189 that holds its edge noticeably longer than a number of my other knives in "lesser" steels, but my favorite for breaking down boxes is a utility knife by Tim Johnson (timos- here) of Black Stone K&T. That blade is AEB-L @ ~60Rc with edge-geometry to make it shine: now ~0.006" behind the edge with a very thin flat (very slightly hollow) behind that up to the ~1/8" spine. The sturdy spine keeps it stiff and comfortable to control, the thin edge makes for easy penetration. In Jim's testing thread, coarse-section (linked below, but everyone knows it, right?) you can read where ZDP-189 in normal Spyderco geometry performs (~420 cuts); a little ways below is a measure for AEB-L (340 cuts) - that is the exact knife I sent to Jim for testing. Does it hold its edge as well as the Spyderco? No. But the thin geometry cuts with such ease, that reduced effort is enough to keep me picking the timos- over it for such a task, plus the narrow bevel requires less metal-removal to restore the apex as needed.
http://www.bladeforums.com/forums/s...based-on-Edge-Retention-cutting-5-8-quot-rope
A video of the timos- and the CalyIII (at 14:20, no need to watch the whole thing):
[video=youtube;rEIX7pMSTHo]https://www.youtube.com/watch?v=rEIX7pMSTHo[/video]
Thanks for the info and links!
I think I always end up with a tiny bit of burr on one side of the blade, but it can't be seen and can barely even be felt. I thought that if you ended up with a true wire edge then only one side of the blade would be sharp, whereas mine are shaving hair with both sides when I'm done sharpening.
I use a sharpmaker. Diamond rods to reprofile, then browns, and whites to finish. Very very light pressure for the last few strokes. No stropping tho.
