I forget about that one. I use it for food prep, which it does so well it's invisible.Here is what I use. It cuts well, is easy to sharpen, is not too big and heavy, looks cool!
I love the look of the Bow River. I am hesitant though because of the 8CR13 steel. Is it heat treated well?
Any decent puukko or Mora type knife would be just fine as long as you get a non-stainless blade.I am fairly inexperienced when it comes to fixed blade knives, and I am looking to pick up a couple budget options to try out. I would like to be able to use it while camping, maybe some bushcraft stuff, and for general use around the house. Ideally I would like something in the 3-4in range, but I am open to others. Eventually I would like to have a custom knife made, but I want to test out some cheaper production knives to get a feel for what I like.
First, I am going to pick up a Mora. I am looking at the Basic 511 Carbon Steel, unless another model would be better?
Some other knives that have peaked my interest are:
1. Buck 684 Bucklite Small in 420HC
2. CRKT SiWi in SK5
3. Brisa Bobtail 80 in 12C27
4. ESEE 3 in 1095
5. Condor Bushlore in 1075
6. CIVIVI M2 Backup in D2
If anyone has used any of these I would love to hear your thoughts. Also, if anyone has any additional recommendations please let me know. Thanks!
My example is. Don't let the steel type scare you away. While this steel is definitely on the low-end of the scale, the heat treatment is dialed in perfectly, and makes up for any "negatives" of this cheaper steel. This is my primary kitchen knife, and it has not let me down in over a year of several-times-a-day use.
A couple older Marttiini knives, top one is a Lapinleuku, ~4.5" blade, bottom is a smaller Ilves model, ~3.75" blade. Both have kydex sheaths from Randy Bagwell -
Stuff like this is easy to find on Ebay for not a whole lot of money.
If you want to go big, as in custom work, you can't go wrong with a blade from Zhelyo Tenev, known as Jelio.
His work isn't cheap but its among the best in the puukko style
In the new category, with 3-4" blade, the Becker BK-11 has a 3 1/4" blade.
You can get the basic knife for a bit over $50, a set of nice wood handles on the bay for $20, and a kydex sheath for $35.
If you are going to be camping and doing "bushcraft", a couple things to consider -
Don't buy a knife with the expectation that it will remain pristine, shiny and new. If you are going to be trying your hand at basic bushcraft stuff like starting fires, you'll need some decent carbon steel to strike a spark. A carbon steel blade will discolor quickly when used regularly for most anything that involves camping and woodcraft. A blade with a coating will get scratched up regardless of what it is if you are going to be batoning the knife as many are prone to do.
Mora in Carbon Steel is all you ever need. Got a $20? You're good.
Either or.Yeah I am gonna pick up a Mora for sure. Which one would you recommend? 511, Companion, Bushcraft, or another?
So exactly what is the price range that you're looking to stay within?
