Hopefully it's not.(munched) Just looks that way in the picture.Visually it looks like the top of the eye is a little larger than the bottom. But the top was beat on a bit and does look peened. I may need to grind out the inside top a bit to get a new handle in there correctly.
Once the peened ridge is ground off, what should the dimensions be? If the top is larger than the bottom, would it be OK to just hang it and shave down the handle a bit?Hopefully it's not.(munched) Just looks that way in the picture.
Great to hear! I'll look into this. The head was on there very tight, and the center has 3 grooves on each side which probably helped, but I would ideally like a taper as it just seems like a better idea to me.The reversible patterns have both sides just as big. As long as you leave a good portion of the handle proud, you will be good. I think I read here about driving the wedge deeper, in order to let the two sides of the kerf spread more and thus fixing the head better at the top.
It's not a reversible pattern, It's a Michigan pattern. On a second look, I think the top of the eye is just mushroomed from where someone tried to drive the head into the handle- no big deal. Just take a file and clean the bur from the inside of the top of the eye, then measure again. It should be 3/4" wide.Great to hear! I'll look into this. The head was on there very tight, and the center has 3 grooves on each side which probably helped, but I would ideally like a taper as it just seems like a better idea to me.
Yeah, that's what I did, it's 5/8" on both sides now after dremeling out that burr carefully.It's not a reversible pattern, It's a Michigan pattern. On a second look, I think the top of the eye is just mushroomed from where someone tried to drive the head into the handle- no big deal. Just take a file and clean the bur from the inside of the top of the eye, then measure again. It should be 3/4" wide.
Thanks, that is what I was thinking you meant, if it works on another axe! Ideally it would be tapered, but I'm more worried about splitting the metal if I did have someone try to drive a metal wedge in there or something.Oh, what I meant is that if it worked for the reversibles, it should work for others as well. I was typing in a hurry, and the picture anyway doesn't load for me...
