That seems to be the general consensus. One of my favorite YouTubers (Project Farm) does a lot of tool reviews and Wiha and Wera usually rate fairly high.I use a combination of Wiha, Wera, and Bondhus tools. They have worked for many years for me.
This was your only mistake. A wera knockoff. Good selection on the others. Wiha vote from me.
You should probably try the wiha’s tooHome depot sells this set for 13 dollars and its diamond coated..... cant get much tougher than that. I have one and its awesome.
Husky Folding Diamond Torx Hex Key Set
Does Wiha have diamond coated sets too?You should probably try the wiha’s too
Don’t know about coatings. They are hardened. The steel usually twists on inexpensive bits under hard use due to material that is not heat treated.Does Wiha have diamond coated sets too?
I figured, but I'm not going to use that for knife work. Just small electronics and cheaper low-torque things. I just thought the design was cool, but now that I know Wera makes a better one, I will surely get it!This was your only mistake. A wera knockoff. Good selection on the others. Wiha vote from me.
The problem with that, is it doesn't go lower than T9. Most knives have at least ONE screw that's T8 or T6.Home depot sells this set for 13 dollars and its diamond coated..... cant get much tougher than that. I have one and its awesome.
It is a cool setup. Been resisting buying one for a whileI figured, but I'm not going to use that for knife work. Just small electronics and cheaper low-torque things. I just thought the design was cool, but now that I know Wera makes a better one, I will surely get it!
not the Torx drivers .Be careful with Wiha, they have moved some of their production to asia...
As mentioned, caveat emptor, the micro bits are Asian made.not the Torx drivers .
anyway, if the handle says made gemani embossed then it's made gemani
basta!
