That is understandable. Many people like a thin knife even when they don't have laws to worry about and I prefer mine to be 0.5" thick or less.
Have you ever carried a knife Inside Waist Band (IWB)? I find it very comfortable and if the clip is behind a belt it's almost impossible to see. Might be worth trying if you have to worry about it being seen. I'm right handed and like to carry mine about the 1 o'clock position assuming straight forward is 12.
Spyderco endura with emerson opener is a great choice all round for what you want.
i'm looking for a flipper or emerson opening that i can open with winter gloves.
It must be "well built" with "fine" tolerances.
Specs
blade length should be around 10-13cm/4-5 inches.
The handle can not be more than 1.3cm/0.6inches thick.
Nor may the handle be wider than 3cm/1.2inches closed.
The knife can not weigh more than 150grams/5.2oz.
Steels prefered: Vg 10, cpm s35vn, cpm s90v, cpm s110v, n690co, elmax, aus-8, zdp-189, cpm m4
it will be used for self-defense, kitchen and to fillet smaller fish.
I would prefer it to be a full flat grind with either trailing point, drop point or standard.
Budget 300$
any suggestions?
How is it to sharpen? Can you compare it to some other steel? Looking at the steel chart it seems close to something like vg-10 or n690co correct?
I haven't had mine too long and have done a light sharpening job and touch ups, but so far it sharpens great. It takes a hair whittling edge easily that still seems a bit aggressive and behaves like more carbide rich steels like M390. I have heard people say it polishes well and takes a mirror edge but I haven't tried.
The edge holding also seems good. From your list I would put it ahead of AUS-8, VG10, n690 and maybe even S30V. I don't have experience with S35VN but it's supposed to be similar to S30V, which I haven't had very good luck with. I don't have experience with Elmax but from what I've read about it I would assume it's similar in edge holding.
The company describes it as a stainless powdered version of D2. I think it might perform a little better than that but that's what it's advertised as.
