Tracy, what do you need for tolerances?????
I think it's time for a "No Weld Surface Grinder"...Because a surface grinder is at the top of my tools list too.
I keep thinking about that. I haven't figured it out yet but I will.
Tolerance is not an issue. I just want the darn bark off it.
I looked at his build several years ago. I'm still impressed. I even picked up a couple cross slides to build one and never finished it. I'm putting it in the job jar....
Tracy, I can do it for you, but I would need to order some 3M 977 36 grits belts.![]()
Can you use 220grit belts if you just skim for a more finished grind on the flats? or what is the highest grit that you have used?
