The grinder is the heart of the knife maker's shop, so you really want to get this right. I have no experience with the AMK, but of the four machines you listed, it would not be my first choice for a couple of reasons. First, it appears the majority of the machine is aluminum which is of course lighter than steel. Light is not something to look for in a grinder. Almost all grinders on the market are made of steel with the exception of the tooling arms. There is a reason for this, you want that mass to lower vibrations and create a smoother running machine. Also threads in aluminum have a tendency to gall. I also notice for some reason there is a standard electrical outlet and switch wired and mounted to the machine. The KBAC drive is mounted in a NEMA 4X enclosure which protects it from dust and moisture. If you ever want to run your grinder wet, which if you do any post heat treat grinding, you will. That outlet is going to be a hazard.
My first choice of your list would be the esteem. Brett makes a great machine and if you're having to wait to get your hands on one, it's because there's a demand for his product. If your concerned about the extra cost, it's really easy to purchase a small wheel attachment on ebay and mount it to a piece of 1-1/2" bar. I put mine together for about $80 with a couple size wheels. Same for a large contact wheel. The horizontal flip base is nothing but a hinged plate. again, easy to construct.
I don't mean to throw a wrench onto your works and I hesitated to post anything, but I assumed you were looking for input. So, that's my 2c for what it's worth.
