- Oct 17, 2007
There is no way your drive wheel wore down from the belt slipping off because of alignment issues. I could see your tracking wheel taking some minor wear over long term use if it was not parallel to the ground and the belt ran on one side of it for an extended period. Even then you should be fine once you get the right alignment.
I used 1/4" wall on my 2" tool arm adapter. I found that 1 1/2" square tube I bought will fit in there very nicely if it was oriented so the weld seams are on the same side. I don't know if using the 1/8" wall could create enough play in the tool arm to make an alignment issue. I have not heard of anyone having problems sticking to the plans in that regard.
Is your abrasive belt tight enough? Some of my belts have about 1/16th side to side travel which looks normal in the videos I have seen. Other belts I use have no side to side travel, but they all behave poorly if there is not enough tension. I played with different springs to get the tension I was looking for. I have read that the KMG has a really stiff spring on it, so much that many add an extended arm for leverage when changing belts. I did the same thing on mine, I think my spring set up pushes close to 50 pounds when it is compressed.
Make sure your belt is fairly tight.
Do your best to figure out the alignment. If you are in good shape, you can run directly from your drive wheel to your 8" contact wheel or small wheel and be close enough to stay on the wheels (completely bypassing the tracking wheel). The tracking wheel should be working to fine tune belt location, not overcome bad alignment.
Make sure your bearings on your small wheel are nice and parallel and not binding. - Loosen the mounting bolts and check how well they spin. They should spin just as well when the bolts are tightened. Even if they bind or are causing enough friction to slip the rubber bushing on the shaft, the belt should still track fine, you will just melt your rubber bushing. PS, make sure that your small wheel shaft is clean and dry so it's not slipping for that reason, although alignment and belt tension really seems like the overall problem here. Good luck.
Try this, once you have confirmed that your drive wheel and 8" contact wheel are reasonably aligned, put the belt on all three wheels and stand above your grinder looking down at the tracking wheel. Using the belt as a reference line, you should be able to see if your tracking wheel is rolling in line with the other two.
Hmmm.... I'm definitely not getting 50lbs of tension on my door spring, but at the same times, it always seems to have been enough in the past. I.E., my belts have never "flown off" the machine when starting on high.
Originally I thought that maybe the drive wheel had just polished the back of the belt so smooth that the belt just didn't have enough grip to be turned by the drive wheel, and this was "pushing" it off. But when I switched to a brand new belt, the same thing happened.
Concerning the play between the tool arm and socket: That problem doesn't exist for my main tool arm socket because it's tapped from the side, so that the tool arms are always tight to one side. It's only on the tool rest socket that there's side to side play because I tapped from the top.
I ran a straight edge from the side of my 8" CW to the drive wheel, and if there are any gaps, they are so insignificant that I doubt it's a contributing factor. As for my tracking wheel, I more/less have that centered so that the crown ALMOST matches the center of the drive and CW. It appears the the edge of the wheel is parallel with the belts and wheels for the most part.
I suppose I could try stepping up to the next heaviest door spring I can find. Perhaps over the last year or so, the spring has just loosened up a bit...
