- Mar 7, 2001
Very nice! Thank you for taking the time and effort to put these through the ringer. Looks like you gave 'em a good workout.
Indeed! Good test and data, thank you!
:thumbup:
Heavyhanded, I have to ask some hard questions.
Do you believe the steels used are as tough or tougher than other knives would be at the same hardness and thickness?
Would you prefer and/or recommend Bluntcut's heat treatment based on what you saw?
Thanks for the detailed report. This is very useful!
HH - you mentioned that the W2 could stand to be thinned out - seems that was based on the lack of damage to the edge as it is right now? Was your idea that it could tolerate being thinner, or that it would be improved in some way by being thinner? Just seeking clarification. I like the blade shape a lot on that one, btw. I do a lot of point-driven cutting during routine chores.
thanks again and hoping the reports will continue to roll in!
Decided to rebevel the 52100 and CruForge V blades to compare to the Scalper. It was set to 12 degrees per side with a hand applied microbevel at 15 dps. I'm rebeveling the 2 comparison knives, though it will be a couple of days.
I also used the M2 knife as a steak knife tonight. It worked well, with the wharncliffe tip protecting the rest of the blade from the plate. Bluntcut, can you provide some information on how you finished the handles? I washed the M2 knife, handle and all. No issues from the water in the handle, but it didn't bead up like I expected based on the smooth finish. My wife also used the M2 knife to cut some pork roast and liked it, though it was too short to be efficient for that use (no fault of the knife, just some use of opportunity).
So been a while since an update. I have been rebeveling the 2 knives above, but took a break during the holidays. So, after cutting some cardboard and rope, I have some more information.
The M2 wharncliffe shaped blade was used for breaking down boxes. The knife cut through about 100 feet of cardboard with no trouble and will still slice receipt paper into fine curls. It will also shave a few hairs off my hand, though obviously not as sharp as the starting edge.
The 1095 knife was used to cut rope. I'm up to 200 cuts on 3/8" manila rope, and it still cuts paper with no trouble. It will also still shave a little bit. I'm using about 2.5 inches of the edge on a plastic cutting board.
Bodog - I am indebted to you for conducted this PA of BCMW knives. your professionalism and conderations are stashed in my long term appreciated bin :thumbup:
Thanks to all had participated & posted-reviews in this PA thread.
Special thanks to Martin/Heavyhanded for your thorough reviews, while invented your EI3K rig!
Jim Ankerson - It's my pleasure to deal with you, a man-of-your-word gentlemen!
==Luong
