- Feb 5, 2010
M390 is available in the US, with a number of sizes to be stocked soon. There is stock now in 4.3mm (.168) in Rialto, CA not far from you
H1 is rust proof steel.It can be left in salt water for years and not rust.It is the only rust proof steel on the market right now,and spyderco is the only production company that uses it at the moment.
The Kershaw Volt will use Bohler M390. It should be out in Feb.
http://www.kershawknives.com/productdetails.php?id=518&brand=kershaw
The Kershaw Speedform will use Uddeholm EL-Max another so called super steel that is new to me.
http://www.kershawknives.com/productdetails.php?id=517&brand=kershaw
I checked out both of those links and was confused. Both of these so-called super steels are used with CPM D2 in composite blades. But I can't tell from the info or pics what steel is used for the edge. You'd think it would be the Bohler M390 and Uddeholm EL-Max on the Volt and Speedform respectively. If that's the case, why would Kershaw use CPM D2 as the "filler" steel. I know CPM D2 is not expensive and its use as filler works in that sense, but it isn't very tough, which I thought was an important characteristic of the filler steels in composite blades. Does my post make sense? I think I even lost myself.
Edit: You beat me to it while I was typing my 12 wpm.Thanks Cotdt.
To be honest I do not understand using CPM D2 as a blade spine material.
As mentioned, the steels share a common HT process. You just can't go throw 2 steels together and expect them to work. Its a science, and Kershaw seems to have it figured out.
Actually, I have another question.As mentioned, the steels share a common HT process. You just can't go throw 2 steels together and expect them to work. Its a science, and Kershaw seems to have it figured out.
Why throw 2 steels together in the first place? I don't see any reason that M390 can't work fine by itself.
Shallot was ZDP-189 edge + 14C28N spine. ZDP-189 is rated at 63-64HRC, and I'm not to sure 14C28N can be hardened to that level.
So, apparently those two are HTed apart and then "thrown together"...
In that case I doubt there is much of a science involved.
Cost. A full blade of ZDP is a lot more expensive than one using it as a cutting edge.
That sheds some light on things. Isn't ZDP-189 heat treated in Seki Japan? So it does seem like ZDP-189 and 14C28N portions are heat treated separately. They both get heat treated in the ~1900F range so they can easily be heat treated together, but it doesn't seem like they are because of ZDP-189's proprietary heat treat.
It seems like they are just using ZDP and D2 to receive the darker etching.
No doubt it does look very cool, but I just don't see where it is necessary, from a performance standpoint, to produce M390 in a composite blade. And if it means having to use CPM-D2 has a secondary steel, there shouldn't be significant cost saving.
