Well, that was uncalled for.
I know it wouldn't be a fair test cause their not the same design,shape,blade length ect. All your doing is repeating what Ankerson has done already and others. I don't give a fuck. I know either the contego or lionsteel would win hands down. Your just repeating shit people have said a thousnad times. Either way i don't fuckin care. For your next test why don't you see how many of your knives you can shove up your ass before you die.Good luck your scientific tests professor.
So given that edge geometry is a significant contributor to rope cutting edge holding tests, what does it mean when a knife with thicker geometry and a shorter blade in a 420HC class steel can cut the 3/8" rope 300 times and still cut notebook paper? I checked a Gerber Remix and made it to 300 cuts and still could slice notebook paper on the first try. The edge is 0.03" at the top of the bevel with a 3" long blade.
I know it wouldn't be a fair test cause their not the same design,shape,blade length ect. All your doing is repeating what Ankerson has done already and others. I don't give a ***. I know either the contego or lionsteel would win hands down. Your just repeating shit people have said a thousnad times. Either way i don't **** care. For your next test why don't you see how many of your knives you can shove up your **** before you die.Good luck your scientific tests professor.
... or a long walk off a short pier ...
Great writeup!
Does the rope used contain anything in it that is abrasive such as certain silicone particles? I am always impressed when I read about M390. It seems to perform well in virtually all conditions, and really leave everything in the dust when it comes to cutting objects that tend to be more abrasive, even when being compared to steels that are 5+ higher in Rockwell Hardness!
Any idea if the M4 Millie is from when Spyderco was supposedly hardening M4 slightly differently (IIRC, I read here earlier models were a little harder)
I just got a M390 blade I am going to EDC...hopefully it won't be too hard for me to sharpen!!!
It really depends...
To really see what that really means one has to compare that 420HC knife to another knife with like geometry....
But to test it by itself it doesn't really mean anything because there isn't anything to really compare it to if you can understand what I am trying to get at here.
Does the Military not have a similar enough geometry? From your measurements, there is only a 0.005" - 002" difference in edge thickness with the Gerber being thicker, and the edge angle of the Gerber is larger. I'm not going to push that whatever Gerber used is better than S30V, but I will say I think rope cutting isn't sensitive enough to tell differences as reliably as was once thought.
So, I'm thinking you didn't like my post? Not sure what about it made you so edgy. With that attitude I don't think you should at with knives at all.
No one attacked you. No one suggested you were wrong. No one has done anything to elicit that response from you. I don't think you are getting the enjoyment out of this hobby that we are. If this upsets you so I would invite you to not participate in any more of my posts. Have a great night. You need it.
