M4 Military
It's true that in general if you want a smaller carbide size you should move to a grade with less wear resistance, however having as much toughness as possible while maintaining extremely great wear resistance is always a good thing.
I mentioned earlier the patent for 3V modified with niobium for finer carbide size: http://www.freepatentsonline.com/y2008/0078475.html Apparently though both Niobium and Vanadium form MC carbides, they are formed independently in casting, so you can have the same volume of carbides but a smaller average size. With the PM process, just like conventional casting, the greater the volume of carbide you have the larger the size, which is why 10V has a greater carbide size than 3V, 10V has ~17% carbide volume and 3V has ~5%, both only have vanadium carbides. Also, this is why the carbides are larger in CPM-154 than in S30V, though they have similar carbide volumes (17.5% vs. 14.5%), CPM-154 has only M7C3 carbides while S30V has 10.5% M7C3 and 4% MC. Since the M7C3 and MC carbides form relatively independently the average size is smaller in S30V than in CPM-154. However, the reason they are designated M7C3 is because it is not only Cr7C3, there is going to be some vanadium and molybdenum in some or all of the M7C3 carbides. If for example S30V modified with niobium now had 5% VC, 5% NbC, and 5% M7C3 carbide than that would be three carbides forming independently during casting (in powder form of course), which could mean a smaller average size, and therefore greater toughness and edge stability. And of course, this would mean 10% MC carbide (from VC and NbC) as opposed to the original 4% MC, which would increase wear resistance. Of course these are just example numbers to make my point, I have no idea what the real numbers would be. The difference in carbide size will likely be smaller in an S30V modification than in the 3V modified with niobium, but there is still a possibility of reduction.
It is true in the case of S110V that the major improvement over S90V is in corrosion resistance, and the carbide size isn't noticeably different, however the carbide volume is slightly greater in S110V than S90V. In the S110V patent there are abrasive wear numbers given, S110V does seem to have slightly greater abrasion resistance, but abrasive wear is primarily a test of the carbide volume and hardness. The crossed-cylinder wear test shows greatly the differences in MC carbide content, which is strangely missing in the patent since it is a favorite of Crucible's. They also of course raised the molybdenum content, as well as increased the maximum hardness attainable. Overall they seem to have matched or come close to the toughness of S90V (based solely on the carbide volume) while increasing the maximum hardness, wear resistance, and corrosion resistance, which is quite impressive.
For the record, I think S30V has considerably greater toughness than S90V, around 30-50% greater.
Larrin, as usual thank you for taking the time to explain this to me. I'm going to have to chew this one over a few times. There is a lot in your post for me that's new. BTW, I wasn't aware that S30V was that much tougher. I thought the mumbers were closer. Still, for such a highly alloyed steel, S90V is doing pretty well, even at 30 to 50% less toughness. Joe
You're welcome, there was quite a bit in that post so I condensed things down considerably, if anything needs clarification I can try to simplify. S90V does have pretty impressive toughness for how wear resistant it is; of course, all of the CPM grades have impressive toughness for the level of wear resistance they have. It's impressive that S90V is somewhat tougher than 440C, which was once considered a "super steel." For me I can't think of a lot of applications where S30V wouldn't have enough wear resistance, but that's just me, S90V just gives an unnecessary reduction in toughness, edge stability, and ease in sharpening for most applications, when S30V has plenty of wear resistance.
Larrin, I'm sure you are already very familiar with this concept, but I think it should be pointed out here that most of our society is founded on not being satisfied with "enough".
Well sure, but with everything being a tradeoff, any steel with more wear resistance (and similar corrosion resistance), is not going to have "enough" toughness, ease of sharpening, or edge stability. Not to mention cost of material and ease of working for the maker. But remember this is only my opinion.
A lot of this thread was way over my head but I think I picked up a few important points.
There will be both an M4 and S110V Mule!
110V has both Nimodium and vanadium.
It has both great wear resistance and good tensile strength which are often hard to get in the same steel.
S90v holds and edge(wear resistance) better than S30V but at the cost of toughness?
The Mule program is not only a hit with the customers but is providing valuable date to Sal and the guys? For example the Bushcrafter is not being made from 52100 now as a result of problems with the Mule production?
Please let me know if I am wrong on any (or possibly all) of these points as it will help me understand better?
If I've understood your posts correctly, CPM S110V addresses the toughness, edge stability, and corrosion resistance aspects of CPM S90V, doesn't it?
Ahh, progress at work.
As far as ease of sharpening goes, I have little sympathy for people who don't want to get a diamond hone, especially for people who pay hundreds of dollars for their high end fancy knives.
Re-profiling an edge is an absolute pain without diamonds, but that's true of most steel types. Just a little less so with the lower alloy types.
I'll stop trying to argue now, thanks very much for your input Larrin.
Good dialog and good info for all.
Thanx to the experts for their input. (That's you Larrin).
sal
S110V doesn't have an increase in edge stability or toughness, but it matches (or at least pretty close) S90V in these aspects while increasing others, mostly corrosion resistance and potential hardness.
You're welcome guys.
Larrin,
Thanks for the excellent posts.
A person needs to know a little about steel before deciding what suits his needs best.
In my case, for the things I use a knife for, I'll gladly trade the toughness of S30V for edge holding of S90V. OTOH, for other users, even S30V may not be tough enough. Depends on how you use a knife, and what you use it for.
