You need to try 3V.
There is no compromise with this stuff.
Every other steel I have ever used had some compromise, except 3V.
3V is not a stainless, but has zero issues with corrosion in normal use.
I have never treated it any different in care than any other steel.
It's really messed me up, I have a hard time using anything else now.
If you like 3v you have to try PD1. I just took delivery on a custom Calavera Cutlery El Patron in PD1 and he switched to it from 3v for his standard steel, because it outperformed 3v in his testing.
I am currently using an El Patron in 3V, great taste in knives man!
PD1 compares more to CruWear than 3V, another really good steal.
I have a good understanding of 3V, I have been using exclusively for about 6 months now. I will keep the insane toughness of 3V for when I am using my knife for something I shouldn't, like prying.
Just to set the record straight, I do like M4, I used a GB for a long time....
I wish more knives where made available in both steels.
you have excellent taste in knives!
ill leave this here for you.
http://zknives.com/knives/steels/steelgraph.php?nm=3V%2CMicro-Melt%20PD1&ni=5217%2C528
Testing of different blade steels
http://www.bladeforums.com/forums/s...ention-cutting-5-8-quot-rope?highlight=cpm+m4
While we are getting off the subject of M4 steel. Here is a funny video about one of my favorite knives and steels, Delica with ZDP-189. It is an incredibly hard steel. I'm not giving up my EDC Gayle Bradley or my D2 composite Kershaw leek, but I have used ZDP-189 years ago with a Spyderco Caly and it was great.
https://www.youtube.com/watch?v=4CuFMgCU31g
In regards to CPM M4 vs CPM 3V, here's crucible's data sheet for 3V.
I use my blade(s) very hard and have broke a few. Obviously, I would rather my blade dull than break, since the broken one becomes useless. So... blade toughness is my 1st priority, edge retention second, corrosion resistance last.
The question is, how tough is tough enough?
The m2 blade I've used for the last 15 years has been thoroughly abused, by most peoples standards, with alot of prying, twisting, and hammering. It's been dropped to concrete floors, once from 30 feet and landing on the tip, leaving a fairly deep gouge in the floor, with just a little chipping of the edge.
From my experience with m2, and m4 being much tougher and wear resistant than m2, I have my answer.
3v shows to be very very tough, which relates to impact/chipping/cracking/breakage resistance, but shows wear resistance (edge retention)at the D2 level, lower than m4, or even m2.
With the above in mind, and according to crucible data sheet, m4 should have better edge retention with identically ground blades and same hardness HT. 3v would be tougher, but m4 toughness is already so high, not sure how much that characteristic would really matter, unless you were doing some extreme prying, or whacking it with a hammer.
Another point is, 3v appears to have a max working hardness of 61-62, while m4 is taken up to 65.
3v would no doubt be one of those forever blades with almost no chance of ever breaking it, but I think m4 falls into that category also, to a lesser degree, with better edge retention.
http://www.crucible.com/PDFs//DataSheets2010/ds3Vv1 2010.pdf
The off-topic part was my fault. I will leave this thread alone, and apologize. M4 is an excellent steel, and like I stated above, more production and custom knives need to be made with it.
Ive broken an m4 blade, but never a 3v or PD1
The CPM version will be significantly better !!!
