nelsonmc said:I had the candy/meat therm touching one of the knife handles, so I'm pretty sure it was almost right on, +/- 10 probably.
WadeF said:You should have put the thermometer on the burner coil. If you got 250F on the knife on the side not touching the burner, the part touching the burner could have been much higher. If you put a peice of metal over a say 3,000 degree flame, the opposite side of the metal isn't going to instanly become 3,000 degrees. Hopefully you only caused some damage to the outter surface of the metal and not all the way through. I'd just give it a fresh sharpening and carry on with your custom colored knife.![]()
nelsonmc said:Got most of the color off with 600 grit sandpaper, but it looks like crap now lol. I'm probably just gonna toss it in the trash or my junker box unless I can get it like sandblasted or finished by someone who knows what they're doing! (Not me) lol
WadeF said:Maybe one of the knife makers will read this, get a laugh out of it, and offer to refinish your knife.If not, you could toss it, or go to like Sears Hardware and pick up some 800 grit, 1000 grit, and 1500 grit sand papers. The higher grits are usually with the automotive paint supplies for sanding your car before painting. They might even have 2000. Just make sure you remove all the scratches from the previous grit before moving to a finer grit. Also you should back the sand paper with some leather or something to keep the pressure more uniform against the knife. You should be able to obtain a nice satin finish this way.
driveljay said:Interesting...
what if you took the knife with you to a local retail store and ran it over the "security tag de-activation pad" on the checkout counter...would that have worked...?
nelsonmc said:Overall after all of this, I got a knife that has an interesting or at least amusing story behind it.
WadeF said:Well, at least you didn't put it in the microwave!Now that would have been a real hoot!
The best way might be to use a toaster oven and set it to 200F and just let the knife sit in there for an hour or two so the knife heats up to 200F all the way through. Right after you could hit it with Militec-1 lube as that stuff works better if it's applied to heated metal.![]()
Now I'll have to check my knives for this problem. If they have it, I'm buying a bulk tape eraser.![]()
yoda4561 said:I bet it doesnt mark the blade surface at allIf you've relegated the knife to the "not really important anymore" bin you might try something else though. If you have a radioshack nearby they should sell archer etchant for printed circuit boards (pcb's) It's fairly concentrated ferric chloride, and will give even the most corrosion resistant of stainless steels a dark black/grey etch given enough soak time. You'll want to dilute it a bit, but not too much, maybe 4 parts water to 1 part Ferric chloride in a glass or plastic container just large enough for the knife parts. Soak it for 5 minutes or so, take it out and clean the surface off if it's starting to get spotty (bubbles form on the steel after some time and cause uneven etching) use steel wool or something, then wash it off with some tap water before soaking again. You may need to adjust the times, it's been a while since I've etched stainless steel enough to give a beadblasted look and it may take longer soaks to get good results. I've done it to my Benchmade AFCK's clip to good effect.
