Can you baton and what not with the Bk5 ?
Well apparently your clever little plan has worked! Cuz now I want one. Crap!
I have been on the fence about the 5, even more so after hearing about the tweener size. I usually cook with one of "my" blades. I was in the kitchen and reached into the drawer and grabbed a freaking Rachel Ray knife! Wha? That drawer needs a Becker. That RR knife needs to be bullied!
i'd be willing to believe the Magnum Camp could baton through the Rachel knife with a minimum of fuss :>
Hey guys. I just wanted to comment on the "thinner" #5.
I have handled old swords that were used in combat and had their normal dings were the blades were almost half the thickness of the magnum. Look at those old butcher knives, green river skinners, the orginal Nessmuk, all those blades were thinner than the magnum. More and more I prefer the thinner blade as simply put, thinner cuts better. It will not do what a thick axe replacement blade will do but it will hold up well.
Good using picture UPNORTH.
Thank you, Mr. Fisk.
Fellas, in case you don't know, we just got visited by knife royalty.
This man designed the BK-5.
I seriously suggest folks go check out http://www.fisk-knives.com/
I had already looked at that thread. It was good to see it.
When I was tweaking the design I kept what purpose I had in mind. The spine cuts down on the weight a good bit. Its other reason to swedge it was to break bone such as leg etc that I might not want the primary edge to cut. Not swedged too much cause then I could not baton it if need be.
The 5 is a companion piece. Much like for long tern in the brush you want a large gun and a pistol.
The more you use one though it will grow on you and you will find yourself going to it more and more. Thats not a sales pitch at all, it is just that the knife will get more use than you would think because it does cut well, from kitchen to other light and medium duty camp chores. Heavy it is not but then again when we go out for a day or two I do not want heavy anything. My hard duty personal bowie for this year only weighs 11 ounces and it has a 10 1/2 inch blade. Thin. Cutting son of a gun
