Hello to all - I am kinda new here - i am an iron worker / millwright - now disabled due to long term back problems stemming from an injury when I was boiler tech on the USS Saratoga during desert shield/storm.
I have a lot of tools and time on my hands - i have a drawer full of old Nicholson files and was reading the threads here on this subject - decided to try it - i am having a problem/question with the non-magnetic state and annealing process.
like someone suggested on one of the threads I got a large baking pan and filled it with fine ash from my wood stove for the slow cooling off aspect - I got my wood stove cranked up full of wood and later when it was full of orange coals i found a way to stoke the coals with a make shift forced draft blower (hair dryer) and was able to get the file red/orange hot.
The problem is i can’t seem to get it to the state where the magnet won’t stick to it -- I don’t no if I am getting it too hot? Or not hot enough?
I had read in one of the threads that as long as it was glowing orange it was OK but I do not know if that is the case?
Please help me with this. I really would like to do it right.
Thank you
STEFANJ, use about 3/8" depth of water in a shallow pan. Hold the blade by the tang with vise grips. Begin at the ricasso and work the flame forward as the color goes through the stages to gray on the spine. Be careful as you approach the point. You will have to lift the rear of the blade up to keep the point from over heating as you get near. You may want a tougher point. If so, let it go to peacock blue and immediately roll it into the water.
I almost always grind my files in the hardened state after a 375f temper, even though I have a heat-treatment oven. It's not much help when the exact alloy isn't known, and it only takes a couple hours to grind a 8" file into a blade.
