- Jul 13, 2009
Some advise;
Use the biggest cylinder you can get for the specs desired - Especially for making billets.
You want the largest shaft possible. A 5" cylinder should be the minimum for pressing billets, as the side load can bend a smaller size piston shaft. 6" would be better.
Use a 16GPM pump at the minimum...or better, a 22GPM. Run it on a 5HP electric motor or a 10+ HP gas motor.
Decide how heavy the frame should be and double that. I'm not kidding when I say the people bend the frames on home built presses regularly. 8X6 I-beam with 1/2" thick webs is on the light side when doing 20-30 tons. 1" thick is better.
An H frame is stronger than a C frame.
Check that the ram and anvil are as close to parallel as possible.
Use a foot control to run the up and down. You need both hands to do billets.
A press isn't as fast as a power hammer, but it can hurt you just as bad. If you are not experienced with using one, get someone to show you how. At the minimum, watch four hours of good quality videos on using a forging press.
Skimp on anything when building a press....and you will be spending your money foolishly.
"You want the largest shaft possible. A 5" cylinder should be the minimum for pressing billets, as the side load can bend a smaller size piston shaft. 6" would be better."
Absolutely, when you order a cylinder to be made to your specs, you can choose from different ram diameter sizes.
Don't just pick one of the premades out of the catalogue if it's not what you need.
That's why I asked about using 2 cylinders in parallel last week to reduce side load
I agree with a big pump, the costs are even no different.
"8X6 I-beam with 1/2" thick webs is on the light side when doing 20-30 tons. 1" thick is better."
Is a 1" thick web available in those sizes?
I use these charts
Maybe I have to look into special order.
http://www.huntersteel.ca/?op=products&id=16
