- Jun 25, 2017
X
but found myself wanting the ability to split more often than cut length.
Or you could go this route.
What you are intending on making is going to be pretty useless as a hatchet, meaning something that cuts using it's own weight when swung.
If that doesn't matter because you'll batton with it, then why not simply batton a light knife for as you say "to split a couple of pieces of wood"?
As far as I know, going ultralight means doing without unnecessary equipment, a hatchet for the majority is considered unnecessary.
I'll say it again, a hatchet with no weight (ok, very little) is just an odd shaped knife as it'll only be good for cutting (provided it's sharp enough) & useless for a hatchets intended purpose of chopping. You can have your own opinions but not your own laws of physics
By the way, my small hatchet has an 8oz head & a handle 19" long that's 3.5oz, good luck making a long handle that is much lighter! The hickory I made it from felt very light.
Anyway, enjoy making it & good luck lets see the finished item....![]()
A cutting froe and saw is what I currently carry. The froe only works with limited pieces of wood and and piece that doesn't work needs considerable effort to remove from the wood, once it's sunk in the 1.75" of its height then that's it, and the handle is so small getting it out sucks, at least with my useless hatchet I'll have a decent length handle and can sink the blade in 4+"You carry a froe. Ever heard of making a quick wedge out of a branch? Maybe rather than more tools more knowledge is in order, that will weigh nothing
If you want to make the funny shaped knife great, you don't have to justify it, it' be a fun project, just bear in mind there is a reason something like that is not widely used already.
Good luck with it![]()
Not sure what terrain or climate you usually hike. If you use hiking stick you might substitute one of them for DIY titanium head Ciupaga or Valaska. A lot of ultra light hikers substitute tents for tarp or hammock just to save on weight.I'll start by saying I know Ti isn't ideal. But follow that up with my goal is something I can carry backpacking, and saving weight. I'd really like it to be under 7oz with handle.
I am planning betta Ti, and precipitation hardening. And wrapping the handle with para-cord.
Thinking 4mm thick, and probably strategic weight reduction, I'd like to somehow make the back a little wider so it could be used as a crappy hammer but mostly so you could pound it into a log with another log type thing.
So with the idea of it needing to be light, do I have a chance of it not being useless? It's pretty expensive to fail hard at my attempt, lol.
I am a little worried about it's strength if used like a pry par a bit.
Jeff,with all due respect but yeah,i'd try to re-calibrate your actual Requirements while out camping,and balance the tooling-up with the actual function.
I've read your thoughts on this,and as a sub-arctic dweller can't really see clear logic there.
Normally,just the saw suffices for everything,even if your heating device depends on a limited length of wood.
(couple years ago i was visited by a couple,friends from long ago,who bicycled down the Iditarod trail from Anchorage to Kotzebue.That's something like 1500 miles on snowmobile trail,carrying everything they needed,in the dead of winter...It was surprisingly little,even to me.They used one of them collapsable Ti stoves,and a little saw...i don't really see what one would do with a hatchet...).
I think I'mSoSharp's right,you may consider separating this potentially cool project from practicality,as it doesn't really want to fit into the reality of keeping warm and fed comfortably out in the woods.
I live not far from the Arctic circle,hundreds of miles from nearest road.Many here travel great distances,with dangerously little gear.And though most carry a hatchet,it's for a slightly different purposes,trail-cutting,making trap-sets,difficult situations where a heavy machine is stuck in very challenging terrain,or falling through the ice...Different scale of rigging,BTU requirements et c....Not quite from the ultra-light opera...
Not forcing it to serve a practical purpose won't take anything away from it's Cool Factor,and i join the previous posters in wishing you the best of luck with it!
But thats the thing: You can't go to light, because weight actually matters on the head of the axe. Sinking in isn't about the length of the handle. It's about the force applied divided by the width of the edge.
Get a shepherds axe or make one like this guy did. Improvising a Shepherd's Axe | Page 2 | BladeForums.com
Some ultralite hikers I've met can be pretty crazy with how little they bring. I'm trying to stay under 20lbs but still carry a sleeping mat and things like that.
An ax was a tool of an economic venture,not of the loose-footed wanderings about,a tool that has to do with the sedentary pursuits,not nomadic.
