- Jan 9, 2017
Stage 1
Sent from my N9515 using Tapatalk
I actually have a analysis for 01tool steel and the paper confirms everything you said... thanksSTRESS RELIEVING
When desirable to relieve the strains of machining, heat slowly to 1050°-1250°F, allow to equalize, and then cool in still air (Strain Relieving).
PREHEAT PRIOR TO HARDENING
Warm slightly before charging into the preheat furnace, which should be operating at about 1100°-1200°F.
HARDENING
After thorough preheating, transfer to the hardening furnace, operating from 1450°-1500°F, depending on the size of the part.
QUENCHING
Quench in warm oil and allow to cool in the oil until a temperature of 125°-150°F has been reached, or to where the part can be held in the bare hand, and temper immediately.
TEMPERING
O1 is generally tempered in the range of 300°-600°F. Tempering temperatures and resulting Rockwell C hardness, based on a 1 inch round samples oil quenched from 1475°F and tempered for 2 hours, are as follows:
Tempering Temperature FRockwell C
300° 65hrc
350°63hrc
400°62.5hrc
450°61hrc
500°60hrc
600°57hrc
I was curious about this so I looked it up and this seems to be the consensus. That being said, I have heard from a few sources that O1 can benefit from a "soak" at its 1400°-1500° temps.
How long of a soak, or even if one Should be used seems to be questioned by the few resources in have checked.
That being said, I would use thus as a guide and not scripture. Make a small necker with no scales and see how it works out. Beat on it, try to break it, see what it can take and if you want more edge holding or toughness...
I'm hoping to find someone close that can help me out with the heat treat and tempering.If I had it to do over again I would have started a little simpler (like without scales) and learned the heat treat process better up front instead of as I went along. Are you using a furnace or forge for heat treating? If using a forge, I will give you the same suggestion I was given, start with something like 1084 as it is easier to get more out of with a basic heat treat. If you have a furnace, more power to you, and jump in with both feet!
Most of all have fun!
I see building a gas forge after I get Christmas paid off!!!
Ya think you could send me a few pics and any hints of your forge?I built a gas forge and actually pleasantly surprised with its performance. Biggest key to it though is getting a good regulator. I had one of the 30 PSI cajun cooker style for boiling crawfish and it would not handle the pressure the burner needed to operate. Swapped for a bigger regulator (and different style) and runs like a champ. Process was very easy just time consuming.
That is why I haven't really started filing or grinding yet... kinda want all my ducks in a row(well ok most of my ducks heading the same direction)!!!!
I hope I make a good blade. I plan on it being on my hip everydayThat's a good thing. I find any time I rush with this, I make dumb mistakes or am not happy with the results. I notice that first time makers who plan and evaluate often make first knives that are significantly above average.
Good to know... Thanks for the info. I'll take pics and post them as I go!Read the Stickies, all the info you'll need is there. Keep your first design simple.
O1 CAN be treated in a forge, but it really benefits from a soak at a precise temps. A kiln would be better.
Keep us updated.
Guess ya have a good point.No 1.. Who are you.
No 2.. Where are you.
Two important issues, we need to know if you're a teenager or a 60 year old retiree with a shop full of tools.
Second if we don't know where you are we cannot refer you to products and services relevant to you and maybe even an offer of help from a local.
Read how to amke a knife in the stickies at the top of the page and then ask questions, we will be glad to help.
