Making the sheat of the ringed damascus fighter
Some pictures of the sheath making process :)
I still haven't finished it, so it will be more!
Drawing the contour to cut the leather.
Cutting the leather.
Punching the holes for the belt loop.
Cutting the leather for the belt loop.
Backside already cutted and punched for the belt.
Glueing other layer of leather for extra thickness.
Drawing the shape of the blade for the front side of the sheath on paper to pass it later into leather.
Presenting the paper mold into the leather to cut the blank.
Front side of the sheath already cutted and presented over the backside.
Drawing the exact contour of the blade on the leather to protect the stitches.
Glueing the protective parts.
img]http://www.aescustomknives.com.ar/images/clydetzsheath12_big.jpg[/img]
Simil blade drawing on the front side for an anaconda skin insert.
Cutting the leather for the anaconda skin insert.
Removed piece.
Placing the anaconda skin insert into place.
Marking the holes for the stitching.
Making the holes for the stitching.
Stitching the anaconda skin to the leather.
Anaconda skin stitched to the leather.
Regards,
Ariel
More pictures.... :)
Adding another layer of leather to reinforce the sheath and protect the stitching for the Anaconda skin.
Glueing the front part.
Smoothing the contour of the sheath using a belt sander.
Marking exact parallel lines to the contour for a proper and even stitching.
Drilling the holes for the stitching.
Paper stencil for a metallic point.
Paper stencil glued to the metal for an exact match.
Metallic point ready to be drilled for future stitching to the sheath.
Drilling the holes on the metallic point for the stitching.
Metallic point, already drilled and etched in acid.
Regards,
Ariel
Something happened at the Argentina NIC, as it affected many local domains. It should be OK now :)
Ok, I finished it... :)
Taking the metallic point out of the electrolitic coppering process jar.
Coppered metallic point ready to be stitched to the sheath.
Dyeing the leather. I first dye the sheath with a brown base and then I use an aerograph to dye the borders and the back.
Almost finished sheath, already dyed and with the metallic point stitched.
Wow, i am amased that all that knowledge is available in one man, it must have taken years to gather all that information and put it togheter to make something that looks right without having to make 20 prototypes.
Great work on the steel and the skin.
big sheath for a big knife!
you whip these things out so fast Ariel.... do you sleep? :D
great job, I like the anaconda insert, and the coppered tip rocks. :cool:
Steve
After looking at this thread again, I'm so happy that I left the choice of sheath in your hands! :D I couldn't have come close to imagining a sheath such as this. Then you even come up with a presentaion display box... YIKES! :eek:
Painstaking craftmanship. Ariel, you are a true artist. Thank you for sharing this fascinating process.
Bill
Very nicely done tutorial. and the pictures explain a lot. a couple questions if you dont mind? What grit sanding belt do you use on the edges? and what size drill bit and speed to drill the holes?
