soooo....
back to the topic at hand; as
D
DevinT
mentioned in a slightly unrelated thread "Design is everything"
when you design a knife, and you plan for how it's going to be used, you choose a thickness of steel that provides the optimal attributes for the intended design. You choose a width, based not only on the thickness you choose, but for the intended use as informed by your design. Then you choose the primary bevel angle(s) and choose where it/they will terminate toward the spine and toward the edge. Then you choose how far up that primary bevel your secondary bevel is going to go/your secondary bevel angle...
all these choices...
they determine so much more about how a given knife is going to perform at its given job than so many other factors that some of us are overly obsessed with, in this thread, at the moment. It would be cool to focus on these other things instead of the effects of sharpening heat has on an edge- which in my view is an entirely different conversation.
the choices made that go into the design of a knife are the most interesting topic, because it gives insight into how and why knifemakers do what they do, and why they are successful at making a good knife or not. Getting bogged down in all this mumbo jumbo is ruining a potentially very enlightening conversation. In my opinion.
