When joeshredd talked about his arm swing he got me thinking, so I went over (again!) Maxeped's specs for the Falcon II and Condor II. They look pretty much equivalent, specially in size, but with one difference that I think is very important: the Falcon II is narrower then the Condor II. With that, for those who won't use a bladder then I guess the best pack would be the Falcon, because you can add side pouches for water bottles and the pack won't get too wide. I think that a Condor II with side pouches would be cumbersome to haul around specially in urban environments.
On the other hand, if you plan on using a bladder, maybe the best would be to get a Condor II. Since it's wider, I think it will better distribute weight around then the "tall and narrow" Falcon II. From the pics on Maxped it looks to be compressable, maybe you can't make a pancake out of it like you can with the Falcon II, but I think you can compress it enough when it's half empty.
I also think that the best way to carry gear in a bag or pack is to compartmentalize your gear in small bags or pouches, because it's easier to add and remove gear that won't be necessary. So I wouldn't need the pack to have many pockets to store my gear. I also intend to use the backpack with a water bladder, since I think it's easier to carry two to three liters of water close to my back, and the weight will always be close to my center of gravity.
Taking into consideration all that, I think that maybe for me a Condor II would be a better option then the Falcon II to use as a general purpose backpack or even a BOB. What do you guys think?
