Cyrano
- Jun 13, 2015
In this thread on the CRK forum, I was warned that sharpening using a belt sander (like my WSKO/BGA) could easily ruin the heat treatment of a blade. It was claimed this could occur even though the blade did not feel hot to the touch, because of increased local heating at the edge apex.
In researching this question on these forums, I found many opinions, explanations, arguments, anecdotal evidence, and hearsay -- including repeated claims that an edge can easily reach 1000 F ! -- but I didn't find any credible experimental results.
To get a measurement of the actual maximum temperature reached at a blade edge during belt sanding, I performed the following experiment:
I created a test blade from a 2mm-thick bar of steel. I used the WSKO/BGA, with its coarsest belt, to create a convex apexed edge along most of the length of the bar.
I marked the edge of the bar with temperature-indicating lacquers, which undergo an irreversible physical change upon reaching a specified temperature.
This photo shows the lacquer as-applied, at low magnification. The purple lacquer has a transition point at 200 F, the red at 300 F, and the green at 400 F:
These photos show the lacquer as-applied, at high magnification, at the edge apex:
I then subjected the blade to aggressive grinding on the WSKO/BGA:
The 200 F lacquer showed obvious transition, but there was no evidence of transition in the 300 F or 400 F lacquers:
From these results I conclude the steel remaining in the blade edge did not reach or exceed 300 F.
- I used the coarsest belt.
- I used the maximum belt speed.
- I pressed the blade into the belt with much more force than I typically use.
- I did not move the blade laterally to grind the entire edge, but instead kept the blade fixed in one position, to maximize heat build-up in the area marked by the lacquer.
- I held the blade in place, under pressure, immobile, until the blade became too hot to hold, which was approximately 60 seconds.
