- Sep 23, 2014
That is exactly what I said...
Ok, but why is this difference important for the purposes of this discussion?Because I was making a point that there is a difference. Total energy vs average energy.
In response to suggestions from bluntcut, I repeated my experiment using real blade steel and a fine-grit belt.
Cyrano - Outstanding followup, thank you :thumbup:
I am a pretend-bonafide NASA re-entry module heat shielder(resume: my thick skin), let me cook up some cool air... hahahaha
I've sharpened thousands of blades on belt grinders and know as fact that the edges can be ruined pretty easily. I do a lot of blade grinding after hardening and with some years under my belt I know what pressure I can apply without damage to the edge or the thinner portions of the blade. I test all edges after grinding for how ductile they are and whether they chip or roll. This will tell you quickly the condition of the edge. No paint on colors, just years of acquired knowledge to come to a conclusion.
IMHO there are too many variables involved to make a declarative statement on whether an edge can survive a belt grinder. I think Bill is in this camp as well. There is just no substitute for decades of experience.
Testing is great and should be carried out by those knowledgeable in the field. People thought the earth was flat at one time; where would we be without having doubts?
Fred
Really?
Here you go. Temperature is not energy, but a measure of it. Heat is energy. Temperature is a measure of heat. coolcosmos.ipac.caltech.edu
But the iceberg has more heat than the pot of boiling water.......
I found on hypefreeblades where Roman Landes talks about measuring the damage from dry grinding
Re: Heating The Very Edge Whilst Sharpening
and there is a link to this image
Example of hardness drop, using a power grinder for sharpening without cooling!
Look at the first dot/data point in the graph and on the edge picture,
its is 0.05 mm or 50 microns away from apex
and it experienced 5 hardness points drop.
The apex is only about 1 microns and easy to damage in dry grinding.
It takes 0.3 mm or 300 microns away from apex to reach good steel / undamaged/original hardness steel That is about three full sharpenings.
Roman Landes said:The pic is taken from a professional gardening scissor.
Maybe a billon blades a year.
It is ground with a 220 grit trizack by hand
Just a little story asside,
one of our knife fellas in Germany was sharpening a standard kitchen chefs knife Solingen on a V rod ceramic stick pair.
By what ever circumstances, a little particle of metal bounced off whilst sharpening, form the blade....
He got it right into the eye, causing a great irritation, so he had to see the doctor.
The doctor removed the particle later on with the comment.
Please wear safety glasses next time you use the power grinder.
He encountered why the doctor thinks he used a power grinder.
An the docs answer was: he figured this, since the particle was burned into the surface of the eye.
Read further in the thread and think about what Landes is proffering:
Regarding the shears-experiment:
The shears will be basic carbon steel, very little alloying elements that can improve hot hardness and reduce damage from such grinding.
There is no detail about the amount of pressure/time used to sharpen the shears - no detail of how much material needed to be removed - only a chart of some hardness measurements, and those measurements are essentially the same (i.e. undamaged steel) back 100 microns from the apex - the damaged steel is all within the first 100 microns, not the first 300. Their hardness tester gives readings between 650 & 675 for everything behind that first 100 microns. It would be helpful to know more about how the results were achieved since Landes is suggesting that crok-stik sharpening can result in burnt edges.... *shrug*
HiRead further in the thread and think about what Landes is proffering: ... Landes is suggesting that crok-stik sharpening can result in burnt edges.... *shrug*
Its constructive? In what way?Agreed and I for one appreciate constructive criticism 😊
Hi
Is that hard to believe?
It's constructive in that he is asking what the controls were and implying that without knowing the variables we do not really know much more than when we started.
people argue, based off of landes research argue that wet grinding will not damage the edge at all ... Who is to say that wet grinding at x speed won't damage the temper..
