No need to air it out anywhere else- it is what it is. I'll send it back and report what they do for me. Thanks for the replies.
bass806, before you send the knife in, can you take a micrometer to the blade and measure the thickness of the steel at the back of the dents as well as the distance from the apex to the back of the dent? Tell us if the damage is >1/16" deep and the edge is <0.015" thick.
FortyTwoBlades is correct that the edge is ground too thin, but the Grasso II is advertised as 5160 steel @ 57-58 Rc, and I have read that BRKT outsources the heat-treatment to Peter's in PA, a respected company. At 57-58Rc, 5160 steel at even 0.015" behind the edge should not take such extreme plastic deformation from chopping wood. My guess is that the metal behind the dents is plenty thick for the advertised hardness, but that the edge is NOT actually 57-58 Rc but is closer to 45-50 Rc, over-tempered, perhaps by machine-grinding. Either that or the damage did not occur as you indicated. YOu are certain that no nails/staples or bricks were involved?
Softer steel requires more material support to prevent deformation, harder steel requires less. Tough steel requires less material support to prevent fracture, brittle steel require more. 5160 @ 57-58 Rc is both hard and tough.
It's funny, the name of the knife always made me think, "Why would anyone want a bolo for cutting grass?" Apparently this knife may only be suited for such tasks...
If you like pocket saws, look into the Silky Pocketboy, Bahco Laplander, and Corona.
That's certainly a valid opinion, but hardly the matter at hand. The question is if bass's chopper should be able to chop, and what should be done if it cannot....as JollyRoger pointed out.
The main reason I responded to this was not so much to the OP but someone else wondering if a chopper is a good outdoor tool vs. considering a smaller bushcraft knife and something like the Gerber saw to process larger pieces of wood. Just based on many years of experience doing backcountry SAR.
I am not questioning your expertise, and I happen to agree with your opinion about the utility of folding saws. I'm just saying you are taking this thread away from its topic. That said, thread drift is quite common.
Efficiency is based more on the user, really. What you find useful, I may not, and vice versa. I am more versatile with machetes and so choppers are more effective for me than an axe would be.Ah, looks like they redesigned it:
http://www.gerbergear.com/Outdoor/Gear/Sliding-Saw_22-41773
This and a proper bushcraft/survival knife like a Fallkniven F1 is a far better combo for outdoors activities IMO. Choppers make no sense to me other than the primal fun of trying to successfully use one (who wouldn't like whacking on stuff with a big ol' blade even if not a terribly efficient tool?).
Just a different perspective on outdoor tools, I guess.
Quote Originally Posted by Grampa.
FWIW, Bark River heat treats its knives to be tough rather than brittle - so you do tend to get dings like this when hitting something harder - like the core of the small branch in your picture. Mike's idea is that it's better when out in the woods to have a bent ding than a chip missing, since you can still use the knife, and on small dings even realign it to some degree. Still, I agree that the edge seems to be ground a bit too fine and should be reground.
Quote Originally Posted by FortyTwoBlades.
The tough heat treatment is not why it got dings. The tough heat treatment is why the blade didn't just completely snap. The real reason it got those massive dings is because there's not nearly enough supporting material behind the edge to keep it from buckling under the impact--i.e. it's ground too thing.
Originally Posted by bass806
Ok, first off I didn't realize how difficult it would be to accurately measure the convex edge of the Grasso. The best I can come up with for the actual edge with my digital caliper is 0.013". That is the point that the caliper rests along the edge of the blade. The 0.013" measurement has bite on both sides of the edge(if that makes sense). This is consistent along the entire edge of the blade until reaching the handle area and then it thickens to about 0.014 to 0.015". Of course if you go further into the edge it increases.
The depth of the dents appears to be 0.011" into the blade and the blade thickness at the top of the dents is 0.025". Hope that makes sense.
Bass, they will take good care of you. If you get it back and don't like how it looks, give me a call. I'll replace it for you.
I don't doubt the Gerber's effectiveness. I've just often seen those three, and the first two in particular, touted as the "cream of the crop" when it comes to folding saws. Just a heads up in case you ever want to try something new (and possibly better.) I don't have personal experience with any of them.Why? I like and have used the Gerber for quite a few years with excellent success.
Next ?, when I send it back to BR- ask for a new knife or have it reground. What do you think would be best so I can continue raking havoc on small tree limbs.
A reground into a thicker edge will most likely make the knife perform as can be expected from a chopper.
If You ask for a replacement must be up to You and BR to discuss.
Otherwise You have the promise from Derrick to fall back upon.
BTW just ordered my first machete from KSF, a Fiddleback Forge 12"!
Regards
Mikael
You're gonna' love it. Though my favorite from the Fiddleback line is the 16".![]()
