Metallic container for boiling and cooking
What about building your PSK around this:
http://www.maxpedition.com/product/product_m4.htm
Put a 1 qt. US army canteen and canteen cup in that
Ya, I find that military surplus covers a lot of my outdoor gear needs. It's cheap, tough and readily available. Snoop through an army surplus outfit, the real deal type. I'm sure that most of your outdoor survival needs will be met. Trench tools, packs, ponchos, etc. Hell, I even have an old steel pot helmet stored away somewhere.:D
I use the lunch box on the left:
http://www.asianawest.com/mulstainstee.html
I get it cheap at the local Chinatown.
It is stainless steel. I pack all my items from my little homemade survival kit in it. Sure it is heavier than aluminum but it is very sturdy. I've accidentally sat on it before. It also keeps water out and has a slight bias towards bouyancy. Broken items are no good, some stuff does't like water, so I am willing to carry a couple extra ounces. Plus it is so polished up that I dont bother with a mirror.
I can and have boiled water and heat food in it over a flame.
Guys,
Why not try some of the heat treat foil the knifemakers use. Its stainless and .002". its tough and a couple of sheets would be light and alot tougher than aluminium. Its also hard to tear.
Thanks
Del
Not small, but I use the GI canteen metal cup. So I got the water, which you will certainly need, a water holder, and a cup that fits under the necessary water holder you're going to use anyway.
To me it makes sense to not get a seperate container to hold water and to nestle it in with the canteen, which will be needed anyway.
http://erdept.smugmug.com/gallery/2244556
The GI canteen and associated cup make perfect sense.
With the PSK, the idea is that it's with you all the time, and compact.
If I have my GI canteen cup&cover, then I have my medium pack too, and lots of goodies.
This is a small PSK. Very small. Basic Basic.
We are talking carrying water in a zip lock bag. No rigid containers.
That's Why I am pursuing what would be considered the "minimal" in size and weight that you could get away with, for boiling/purifying.
An aluminum hikers fuel bottle would serve as a boiling container and canteen, all in one, but, I'm looking for what will fit in a small PSK.
But, thanks and keep the ideas coming!
Good stuff here.
how about some of those aluminum foil cooking bags, they are heavy foil, and would pack small for your kit.
alex
Someone described a billy pot as being simillar to a paint can. now I wouldn't use a used paint can for cooking but my local ace hardware store sells new ones in different sizes. I was thinking about putting together some kits in gallon cans and tossing them in the trunks of my kids cars. I won't cover the contents and uses that has been dicussed before and will be again I'm sure. The cans are pretty much air tite and should be good for food, water and gear storage. thought I would tape a p38 or p51 to the outsides to open it with.
If you're looking to heat up enough water to sterilize, then a tobacco tin should be good enough, no? Mine measures 3-1/8"W x 4-1/4"L x1"D (78mm x108mm x26mm), and holds 4 oz water. The Altoids type tin is a little smaller but, again, would hold enough for sterilizing.
Someone (fixer27?) mentioned putting hot stones in a container. On one of those survival shows a few weeks back, the "expert" poured water into his canvas boonie-type hat, then placed hot rocks from his fire into it, removing two or three with sticks and replacing them with new stones after 30 seconds or so. To my surprise, the water actually reached boiling point. Lesson learned for me.
Most canvas hats, mil-surplus to Tillys and others, have venting holes that need to be filled with something. But besides that, I imagine anyone of them should be able to do the above. A heavy canvas bag, or even a cotton canvas coat a la Filson, could hold even more water, although they would probably require exponentially more effort to heat up that much more volume too.
Of course, if one takes a spill in a river, goes overboard, etc., I suppose one might well lose the hat, bag and coat. And if you still have your coat and/or backpack/bag, you should have a small metal cup or pot anyway. But the redundancy, and creative ideas for using of "what have you" might be worthwhile anyway.
As per bowieman's father, I grew up carrying a Sierra cup hooked to my belt when hiking or camping, but haven't done so in many years. But keeping a metal cup secured to one's body, with aluminum foil as a backup in a survival tin, might be the best idea if one "absolutely positively" must have something to boil a decent quantity of water.
I may have to pick one of these up it seems like one of the most "pocket sized" suggestions yet.
Jimi,
Just a thought but rather than cutting down a coffee can.....How about a planters peanut can? It's about the same diameter but about half the height...
