- Jan 6, 2015
The most optimal set should be as follows: at the beginning, use stones with a copper-tin bond, say 200/160, 100/80, 50/40. And closer to the finish, take stones with an organic bond: 20/14, 7/5, 3/2
As far as quality goes, they are good. But I think you mentioned that you already have a set of Venev MS-1 stones in another thread? If so, then a set of Poltava metallic bonded stones will be very much the same type of stones.So poltava quality is good to go
I was thinking the same thing about the resin one after ready what everyone wrote. As far brand should I stick with venev or try Poltava
Second that.I would stick to Venev if you're going to go for resin based stones.
The resin breaks down during use and can be refreshed easier if needed, similar to many waterstones. It also leaves a finer edge.What is reasoning to pick venev resin over Poltava
No I am meaning paltova resin Vs venev resin. Why venev over paltova brand
Count vouch for everything said here.Venev resin based stones have been thoroughly tested for a long time by many sharpeners with great results and Venev resin based stones are readily available if you need replacement or after sales support.
Venev resin based stones have a proven track record in and is known for their excellent performance.
The diamonds are part-embedded in the resin, with only part of the diamond sticking out. On a plate, the diamonds are fully out in the open, and backed by a hard surface, so they cut deeper given the same pressure.can someone save me the time spent researching and explain exactly why resin bonded diamond/cbn produces a finer finish than electroplating bonding given identical grit size?
thank youThe diamonds are part-embedded in the resin, with only part of the diamond sticking out. On a plate, the diamonds are fully out in the open, and backed by a hard surface, so they cut deeper given the same pressure.
Sorry for the late response to this question,I the Venev are better stones for fine edge's and the nature of the resin refines the edge more then the Poltava's.This is an old post so hopefully I get a response.
How do you like the quality of the Poltava premiums Vs venev? I'm thinking of buying their premium CBN stones. Or should I just go with venev
