cucharadedragon said:How do these compare to the originals? Are they still big and fat or are they more streamline? What models are they for? Crewman I hope!
pastorsoup said:One thing i meant to ask the rep this morning was the exact type of micarta that is used for the scales. Do any of you guys know what is used? Is it a green linen micarta? Just curious. Also, I saw somewhere on the web a guy that used his old scales as a survival capsul worn around the neck with paracord. Not a bad idea!
Soup
rouger77767 said:If you have some tools you can buy your own slabs from knife-making supply houses. They are MUCH cheaper then $20.00. I think the last set that I bought was $3.50 for 2 pcs at 1.5" X 5". You can also choose the thickness.
There is a lot of grinding/sanding/drilling you have to do though. So the $20.00 may not be a bad deal if you don't have toe equiptment or just don't want to do it. I like doing that kind of stuff, plus it gives you a "personalized" handle.
Just a thought
Roger
sodak said:I have heard that sanding or grinding micarta is very dangerous without the proper equipment to protect your lungs, so a little safety plug here might be in order..... No, I'm not a lawyer!![]()
-SandoMicarta gives off fumes while grinding, you need a resporator filter designed to filter organic compounds. That's supposed to take care of the formaldahyde micarta gives off.
-Mike HullYou will need cartridges that are rated for "organic vapor", AND "formaldehyde". Micarta gives off both phenol, and formaldehyde gases.The phenol is handled by the organic vapor part, but the formaldehyde requires extra protection, hence a dual rated cartridge.
-Mike HullAs far as the dust not being dangerous, I beg to differ, but I got it straight from a dept of health toxic materials guy in Californis some years ago that it WILL absorb through the skin, especially if you are sweating. I placed that call after coming down from a micarta induced bout of serious high blood pressure, and rage. It was so bad that I spent 8-10 hours laying in bed and grinding my teeth before it wore off.
-Mike HullWhen I became more rational, I called the health dept., and finally got ahold of this guy. He told me that exposure to phenolic resin gases can produce reactions that are much like the drug "PCP". A super adrenalin flow that can last hours, and result in sensitivity to chemicals(me) etc.
If you planned on doing more in the future then a small investment isn't bad or if you wanted a different color then the Extreme handles, but I think for most the $20 is worth it.pict said:Powells85,
That $20 is starting to look like a better deal after all. Thanks for the heads up. Mac
