Micro Bawanna Bowie Folder concept.
He's definitely one you want on your side of the fence. If he likes you he will do anything for ya. Dont mess with his kitty cat!
5ed699fa68540e585c32f2bccc35a355
Whhaaaaaa!!!! Im Done!!!!! What the heck am I gonna do now? Crank up you Hays 1200 baud Smart Modem! Ya wanted more pics:thumbup:
Since those last pics I polished up some internal guts and did some fine tuning, cleaning, and lubing.
Heres the final specs:
Over All Length: 9.5”
Blade length: 4.0”
Blade made by Min Kami which was an apprentice of Bhakta Kami.
Handle length: 5.5”
Weight: ready for this? ONE POUND!!!
f23494d9120dfe875505dd3484be32f5
Equal to one KLVUK minus one KLFVUK.
Scales are Stabilized Oregon Maple and are removable. 1911 handgun grip bushings were used to secure them to the brass frame. Special thanks to Bawannas expertise in getting them installed. Also a special thanks to Bookie for providing the brass sheet for the frame. Gracias Mi Amigos:thumbup:
169ea4af39d5bbc7ec2d8fdbea30498b
For evey part you see here there were probably a half dozen made you dont see piled up in the shop. The lockbar by far being the hardest piece to fabricate. You can see I finally got the third hole placed properly. You dont drill that hole till your all done btw. The lockbar and spring were quenched and heat treated via the Bookie sardine can method on his Toad Hall website. I will take that little trick to my grave:thumbup: A few springs were broken while testing so spring making wasnt the easiest of task for a newbie either. What I couldnt buy I fabricated from drill bits or whatever I had on hand. Most folder parts are not anything near the size I needed for this monster. That lockbar by the way was supposed to be about five times thicker than it is where you push it but it seemed to keep loosing weight during fabrication and trimming. Ill remake one someday but no dang way im doing it anytime soon. It works and you know what they say about that:D
5b42f0e0beaf51965227e1021bedff48
Overall I am very pleased with it and the action is even better than I expected. I even picked it up backwards a while ago and was going to flick it open to show my wife and it opened with a loud snap but backwards pointing at my gut. She laughed of course. Hey it works!
8a382031f5fd13e836acfe1ff736b6a1
You can see the bearings in there if ya hold your thumb out and close one eye.
3be2d616c768278729e7c7d7a658d015
4b35286662aa2cfd82fa13c1c914a53b
d3461dee5b508d3a15f7e0977e23e715
There is a little bit of a gap in between the scales and bolster but not enought to worry about. I had them perfect but when I drilled the bushing holes I musta got off a bit on my cheap Chinese drill press. I let it be and went ahead and trimmed the meat off the scales down to the brass and called it done. Next set of scales will be perfect! Ha!
f7125ab49c3cde623575565ab6542f9f
A little bit of trimming on the spine to match up to the lockbar. no biggie there.
b1bfe3c853885afd404e555d32a5f4a9
1d3c317b5cf7f910809877c5944b81d4
The spring is on the right there and was made from a piece of drill bit. I flattened one end bent it, hardened it again and then tempered it to spring temper...duh...its a spring. You may also notice the cuts on the bottom of the lockbar. I thought id need the clearance so the blade wouldnt hit in that area but turns out i didnt need to do that.
8140bdfcfe5ddca79d5888e2dee16aaa
I did have to trim the area behind the cho to make it work. That was mandatory. Everything in that area was really tight. My plan was to use a Bhakta blade but when I ordered I got a Min blade which is wider. That required a complete new model.
1f306c28ab2cbf56a8e9f830596df866
83a4ae482e3069a882c9aba7fc577295
e3136b68fdbfda33b3224416f5a9a6d9
Theres a bit of scale for ya!
ab50ee04755f5a33a08d0020abe7e268
There it is folks! Thanks for everyone's comments and suggestions on this project. They really have been helpful. Next one is going to have my blade and then I can call it mine all mine!
e87e9b305db2416652dfea3607df4cf3
ndog: This is breathtaking. I'm not a folder fan in general but I've seen many photos of folders on the Bladeforums Exchange, and I've never seen one as flat out desirable as this one. The process that you went through seems in the spirit of the handmade blades of the KI kamis, even though you used equipment that they don't have. Also, compliments on your photographic skill.
Well done sir well done. I think it is amazing and dont have enough words to say how beautiful it is. My hat is off to ya.
Man that's really something. Very well done on all counts. You can hold your head up on that one.
I'm switching from drool buckets to beach towels.
Reading this thread has been educational, inspiring, and fun. Awesome creative powers at work here. I like happy endings.
I can not believe the beauty of this. It is amazing! I agree with Steve, this has been one of the most fascinating threads I have ever read through. Step by step the process evolved and went from an interesting idea to a simply incredible piece of blade art. I am thankful that you let us come along on your journey to completion. Thank you!
Very worthy use of all that brass Kamidog. I am proud of you and your efforts. It's really an accomplishment!
That's beautifully done. You're gonna have to buy some suspenders now, and reinforce a pants pocket or two...
Ha! Right JW! I should have put d-rings on it for baldric carry:D
Bookie: actually the brass is one of the things that worked out very well. I still have half of it left. I think I had to remake one little piece of the bolster but definitely a few more projects left over. That was an awesome idea btw. The color once polished is like gold! Just beautiful.
Really glad everyone enjoyed this thread.
Want some fries with that Berkley? Or I can mash up some taters with this thing in a jiffy!
Truely a stunning piece kami dog... I love it and the 1911 bushings were a great idea. That has to be the nicest folder I have seen in a very long time.
Thanks gb! Yeah that was Bawannas ideer. Great but now I gotta make another set of scales for it;) I think ill make some zebra wood scales next. Not anytime soon tho. Gotta let this project age some first.
Super impressive work all around on that big boy, Danny. It really turned out great. The handle design looks super comfy, too.
