DocNightfall,
Your post is almost a year old so I don't know if you are still reading this thread but a couple of months ago I did just what you mentioned here. I use an Edge Pro sharpener and set it to 18 degrees per side and put a good edge on a VG-10 Endura. Then I lowered the angle to 16 degrees and hit the blade with a few strokes. Then I lowered it to 14, then 12, then 10 degrees creating narrow bevels at each angle. This created a pretty close to a convex edge. Then I went back and put a true micro bevel on the very edge at 21 degrees with a 1000 grit water stone. You can barely see the 21 degree bevel. This created possibly the best slicing knife I had ever sharpened. I could go back and hit the entire edge at 19, 17, 15, 13 and 11 degrees to almost erase the appearance of flat bevels but I haven't done that. I probably will one day when I am EXTRA bored.
This was very easy with the edge pro because there are no limitations on what angles you can set it to. I can even mark the edge with a marker, set to edge pro to the angle I want and it will hit the edge exactly the same as when I first sharpened it. The EP comes with marks at the 15, 18, 21 and 24 degree settings. One modification I did to my Edge Pro is I used a circular level like was mentioned earlier in this thread and marked my "angle rod" at one degree increments. I used a fine tip sharpie then a Dremel to cut small grooves for each degree. That helps a lot if you want to be that precise (which really isn't needed). I just had more time on my hands than needed I guess.
Jack
Jack
