military 2??
Am I the only one that thinks its time for the next gen military? Don't get me wrong, I think the current military is an awesome knife (obviously). However, when compared to newer spydercos it is clearly outdated. It just needs a few modern tweaks but still, would be awesome.
Opinions? thoughts? ideas? information?
I won't buy one if they do. I like my three current Military's just fine. May even buy a titanium one soon. Will not buy a M2. Especially if the change involves some bells and whistles lock, when the liner lock is just fine thank you very much.
If you aren't interested then don't post. If you continue to push for advancement the sooner it will come. "discontent is the first necessity of progress." (Thomas Edison). Also I would vote that the knife stay largely the same but have a few minor upgrades. (i.e: pivot bushing, better clip, larger lanyard hole, ect).
The Military is a touchy model for updating IMO. It has weathered the test of time and still seems to be a popular model every year. There was more room for improvement on the Para 1, which is why the Para 2 came first. To me, the Military is like a screwdriver or other common tool. It works so well, and is so simple, that it doesn't require changes to stay relevant. That doesn't mean that minor updates wouldn't be welcome. For years the Military was expected to be the the first model that would introduce the fabled stop lock. We might still see a Military 2 with the stop lock once the get it fully refined. Even with a new Military on scene, Spyderco would likely keep the standard linerlock version in the lineup.
Well, here are the thoughts mainly on the Military 2 with the threads popping up for it.
People want:
- 4 way clip
- compression lock
- stronger tip
- leave it the way it is
- tip down
- tip up
- stop lock (can be seen in this link)
- Low rider clip
It is a constant back and forth, some want "hard use" others want slicer, some ant it bigger, some want it smaller, there is no clear cut line. All the threads are a back and forth and never a conclusion. Here was one of my posts for my opinion on leaving it the way it is:
Very true. especially if you take its design philosophy into account that was mainly for gloved hands. Following are my thoughts, at the end, its just preference.
[video=youtube;qdYOY_6RfQI]http://www.youtube.com/watch?v=qdYOY_6RfQI[/video]
Here are comments from Sal that can be found with the search feature. Many have to do with the lock, because many question that part on the knife. I highlighted the most important bit for me. The Military is probably the best selling production knife (IMO) for a good reason. Buy one and enjoy.
Sal Glesser on Military
Good points and good discussion.
I think that it is important to "peel the onion" in making these determinations. Also one must include "time" and refinement" in analysis.
Any lock can fail. If you didn't hear it. Any lock can fail.
Locks are bits of metal cut to very close tolerances and carefully balanced heat treats. The interface area is ciritical.
Failure can occur from error, out of spec, wear (time), dirt affecting the interface, excess force, which bends or coins the interface, etc.
Locks require maintenance, attention, occasional light spine tap to check. In case you didn't hear that, light is the key word. I see many locks that have seen "death by spine-wack". Expectations are often too high in this area, in my opinion. If a light tap defeats the lock, then inspection, cleaning, etc can save the lock. Each time it defeats, it "breaks" a tiny bit more. Continual spine whacking without making a change and expecting a change is not logical. It also ruins the lock.
With that in mind.
Each lock mechanism has advantages and disadvantages. Manufactures continually refine to reduce disadvantages. Eg: We're on our 3rd lock material on our Military in 10 years. As manufacturers learn more, they improve. (time again).
The Walker linerlock has some very nice advantages; easy one hand open and close, smooth action, easy to overcome closing force for easy opening, takes up little space affording far more flexibility in design. Simplicity of concept.
disadvantages; it's difficult to make reliablle. Much attention needs to be paid to the materials and hardness of the blade material (tang) and lock interface. (This is also true of lock-backs, Axis-locks, compression-locks, E-Locks, Reeve-Integral-Locks, ball-bearing-locks, etc).
On the Military we've contually refined this area. We use an offset concave arc ramp for greater reliability. We precisely control angles and hardness of the interface materials. We've gone to dual nested liners (very close tolerance) with focus on greater ridgidity. We could go to a LAWKS like CRKT and we' ve considered it, but at this time, we would prefer to evolve the Walker Linerlock to improve reliability without the addtional parts.
Does this make it perfect? Of course not. Any lock can fail.
But with the constantly improved materials, tolerances, hardness balance, they get better and better.
This is, IMO, true of any lock.
sal
Gene - Thank you. The Military Model was designed to be the "state of the art" Produc tion folder of the time. We believe the 2nd generation version is that. Every one of the many parts in this model was examined and refined. We listen to all of the comments (good and some negative), but our own constant testing enforces our beliefs. We believe that nested liners are more evolved and stronger than separate liners. And more expensive to produce. (Ask for favorite custom maker how much more they will charge you to nest their "full liner" just inside the scale like Spyderco's Military). "Form", in addition to the "pins" create rigidity. It may be possible to "white knuckle" a lock release, but this hasn't happened to our knowledge. Being able to easily close the knife after hard user with gloves on was a major consideration. Any of you that have had a folder lock open and not be able to close it? It's like a chain saw that won't stop...what do you do with it? The new "SecurLok" that Frank Centofante invented is scheduled to be added to the Military Model somethime in '99. This would eliminate the fear of accidental lock release.
The Military Model was not designed as a fighting knife, nor was it designed for suit and tie carry. It was designed to be the most dependable cutting tool accessory a soldier might need while in the "bush". The handle is a little larger to afford the dual grip potential. Design is always a great discussion because there are so many points of view. eg: blades are for cutting, handles are for holding. A 2" blade specifically designed for controlled cutting loses it's ability to control if the handle is only just long enough to cover the blade. Nothing to purchase on. A scalpel is a good example of this. What is the knife designed to do. Look at? by all means, balance the sizes to apperarance, use? tougher problem here. Just one designers point of view. I have avoided responding to this thread as it was my design in question and this was a comparision type question. It would be expected that I would be biased.
sal
Design preferences make the industry interesting. Both Gayle and Ed are of the opinion that the relief is not as safe as no relief. Both are highly skilled at designing knives, making knives and cutting with them. Both are champion cutters in competition. My linerlock designs include a relief. I'm often wearing gloves and I prefer them in general. I've heard many complain about my Military and Sage linerlock designs because they feel the relief is unsafe.
Both approaches are valid. That's why we make both. For those that want a relief, it's easier to create one.
sal
Perhaps "Practice" and "theory" are two legs on the same body, taking turns to move forward.?
Some thoughts to share on the linerlock lock up. Linerlocks are very tricky with the angles of the mating of the tang/lock as well as the hardness of each surface and inheirant qualities of the materials. It is difficult if not impossible to create the right combination that will "lock" properly with light effort and still work well with heavy effort. When one "throws" out the blade using inertia, the force at contact is very great. More oftren than not, such force will push the liner farther over or "tighter" than the light aforementioned pressure was designed for. I would guess that in such a lock up case, the blade was snapped out using inertia and the liner simply locked up too tight to easily unlock. We also found that titanium was a little "grabbier" and "bendier" than steel and even magnified the problem more. I believe that most linerlocks that are opened as designed would probably not have a problem. (assuming geometries and hardness are proper)
sal
Use the search feature. This horse is well beyond dead.
Murdamook is right, this is a low and far-off priority, and for everyone who posts that they want a Mk2 Military there are a ton of people who post that they don't want to see changes. It will happen, but don't hold your breath.
I think it needs updated. I especially want a 4 way clip and larger lanyard hole.
I agree with you, but I said the same thing about the Paramilitary. Lo and behold, after I got one and used it a bit, I had to admit that the Para2 is quite an improvement. When Spyderco gets around to it, odds are high that most of us will like it quite a lot! :thumbup: :D
Military2? Great! As long as they keep the original available also, I don't see the harm in it.
I would like to see a fixed blade version. I have never gripped a knife that felt better in the hand than the Military. I fixed blade version of this would be the ultimate knife for me.
I would be in for a FB millie, thats for sure.
One think i would be glad to see again even if it has no impact on performance is the diamond engraving on the blade as seen on 440v version, it was quite unique and so sexy.
Im really eager to see a millie v2 and i kinda hope they will go for an exotic steel as regular production run, also i would like to see the same kind of clip with equilateral triangle screws as they are by far the most heavy duty clip from Spyderco, no deep pocket or such thing belongs to the millie.
Ease of access and durability > stealth carry by far.
Edit : While im happy to see a new proprietary lock design by Spyderco, i would be more pleased with a well rounded and already time proven lock, the compression lock, seeing the craze for pm2, this is much more logical to me to go that way for a millie mark2.
If the Military 2 arrives with a compression-like lock...I'll buy one right away.
I agree with this. ^^^^
Not too concerned with the pocket clip, but the liner lock and how it impacts my forefinger is a real turnoff for me. The compression lock does away with that issue. I own a camo/black Military and am still trying to decide if I want to sell it. A compression lock would make it a whole new ball game for me.
I would like to see one with tip up option and larger lanyard hole. I say leave the lock because that sets it apart from the Para 2 IMO.
The only thing remotely annoying about the Millie IMO is the right hand only pocket clip, which is easily remedied by getting the left handed version. Millie2 with 4-clip, stop lock and Para2 style lanyard hole would be really cool as an alternative alongside the regular Millie though.
what super steel (ex-s30v) would you want as a regular offering and how many of those are you willing to buy (at what price?)
If the Military 2 arrives with a compression-like lock and a 4 way pocket-clip, I'll buy one right away.
Negative, it will have the new Stop Lock. You might like it, though - it looks interesting, strong, durable and easy to use.
Sal has said that Spyderco will continue the original Military in production. :thumbup:
I agree.
