I have had a mini Axis for a few weeks. So far I like it. It has a coated plain blade. It opens smoothly. It did seem a bit thick for its size when I first got it although after carrying and using it for awhile, it seems fine. I would have prefered a flat ground blade but this one cuts okay. I think it is a great knife for light use. I wouldn't recommend it for heavy field use, but I don't think it was designed for that. I would absolutely buy another. One caveat. The blade is not sharpened all the way to the handle.
If you try to sharpen the blade all the way to the handle, be careful if you go less that 20 degrees. It is very easy to grind away the opening studs. Another plus for a hole. I used a piece of cardboard held against the side of the stud to protect it.
Danny
[This message has been edited by dfhoward (edited 03 September 1999).]
Danny
