So is anyone aware of Spyderco's micron coversion, or grit conversion on their ceramics? I am definitely interested in trying some coarser finishes. As I usually go right up to Spyderco's Ultra Fine and then to .25 Micron diamonds on a strop.
The brown Med rods are around 14~15 Micron, Fine is around 6 Microns, UF is around 3 Microns.
Thanks Ankerson. I am on Congress Tools now. I think I am going to try the SiC stones, which stone size did you buy? The 1 x 1/2 x 6?
I do it cause I like the looks of it, I generally add a Microbevel right after its done. It also reminds me how far my freehanding has come
I was comparing ~14 Micron to .5 Micron.
Really? There have been whole threads to that effect. Ankerson seems to be the most notable person that touts the coarse edge now, ironically. He used to be a polished edge person, now he stops at about 400 grit on most everything as far as I know. I too have started using coarser edges, but not as low as Jim, and not on all knives. Different uses, different edges.
We also tested in different ways with different parameters, no contention. A major difference is that the CATRA test maintains the same load throughout, so there's no comparison of how little force can be used to slice, or how much you have to increase the force to continue slicing. The similar performance in that respect is not too surprising, wear on the same steel is going to happen in the same way when you are doing the same thing.
It does show that the level of polish is not as detrimental as some people believe, in that they think sharper edges and more polished edges somehow cut less by mechanically failing earlier.
I have known and been friends with Ank here on the forums for quite a few years. It really is not ironic to me, it takes experimenting with edges of all kinds to really have a well founded opinion. This is of course IMO.
Anyhow, I prefer a toothier edge for my small tradtional EDC knives but mirror polish or toothy they still cut...
I just made a short video of my mirror edged machete. I feel like its been a few years since I modded this one up. It has seen a lot of use, crushed into a few concrete walls around the barn and taken a beating doing what machetes do. In the three years I have done nothing more than strop the edge with different compounds on my leather belt on a grinder. The edge is not perfect but who cares. Here you go...didn't have any newspaper.
[video=youtube;fX95Kil5t0s]http://www.youtube.com/watch?v=fX95Kil5t0s&feature=youtu.be[/video]
Mirrored edges or polish edges have only 1 defect, polish edges having hard time cutting synthetic staff that's all.
For the rest I don't believe that a toothy edges will cut better or having better edge retention than more finish polish edges. It's a dream.
Anyone who want to change my mind, better to starting showing some evidence or Data. More refinish the polished edge is, and more microscopic small the toothy edge became 2+2=4.
Some of us have tons of data to back it up.![]()
Will you share some of it with us?
I got these, and in a bunch of different grits, they're so cheap, I wanted to try them. They are really different from anything I've used, they're smaller than a bench stone, and you HAVE to use a lubricant. I took a stroke across the stone dry, and a cloud of abrasive billowed up. You don't want to be breathing that. These things suck up water like a waterstone, but they work well, I'm still getting the hang of them.
