- Dec 27, 2010
There are plenty of makers who swear by toothy edges over mirror finish ones. I can do both, and have used both. I'm leaning more and more towards toothy for most applications, because they are distinctly better for slicing, and it's a lot more mechanically common to slice than to push cut. I'll put a mirror convex on a chopper sometimes, but for most knives a toothy edge is better in my estimation.
Think of it this way, if you're like kurodrago and you think mirrored edges are always better. If that were true, serrated edges would never have been invented. Do you use a straight edge to cut wood? Funny how all saws have teeth, isn't it? If you were correct, shouldn't they all be mirror polished plain edges? There's a mechanical advantage inherent in a toothy edge. Might come from the increased edge area, might just come from the geometry. This one's really a no-brainer, and easy to verify. Try cutting some manila rope in a slicing fashion with a serrated edge, and try cutting it with a plain edge.
It's actually not that easy to get a really good toothy edge though. You have to get the grit to go 90 degrees away from the cutting edge, and then knock the burr off. Most people and sharpening devices run diagonally or parallel to the cutting edge, and that's not going to give you a mechanical advantage. I think this type of edge is called the ACA edge or microserrated edge by various people and companies. RyanW put one of these edges on his new SPK knife, for instance.
I can't deny that a mirrored edge is better for push cutting. But how often do you slice things, and how often do you push cut? And slicing is generally a more mechanically efficient way to perform the same task that push cutting does. So which is a superior edge? I'm not betting on the mirrored edge, as pretty as they look.
