Modified Drop Point Hunter **VIDEO ADDED**
TK Steingass
Troglodyte Knifemaker
Feedback: +110 / =0 / -0
Greetings All, For your consideration is this Steingass modified Loveless style dropped hunter in CPM Magnacut/Exhibition Grade Bastogne Walnut. The stabilized Bastogne walnut has beautiful crotch flame figure on both sides, with cherry red G-10 liners on the tapered tang. The hollow ground Maganacut blade has a hand rubbed 800 grit satin finish. The handle is all Loveless style whereas the difference is the blade. The bottom of the ricasso is flat rather than round, the cutting edge drops below the ricasso 1/16" to preserve the blade profile after repeated sharpening, there are thumb serrations on the spine, and finally, the blade has a bit less belly than the original Loveless Dropped Hunter.. The solder joint is perfectly executed with no pinholes. The Loveless style sheath incorporates a cam to retain the knife securely. I hope you like it! The first "I'll take it," PM, or email gets it. $490 delivered CONUS. PayPal preferred, checks, and money orders accepted. Thanks for viewing, all comments appreciated.
V/R, TK
BASTOGNE KNIFE VIDEO
.220" CPM Magnacut stock
HT to Rc 60-61
8 1/4" OAL
4" Hollow ground blade
Spine thumb serrations
Pinned/soldered guard
Exhibition grade Bastogne Walnut
Cherry red liners on tapered tang
Stainless fittings
Loveless style cam sheath
