- Nov 16, 2002
When you it put it that way, Joshua J, my pal, Ken's 25 nanometer polishing compounds are just barely scratching the surface.
I'm seeing a lot of comments where the poster has constructed a model of the system in which to apply their reasoning. And not a lot of it make sense.
I'm going to go with either "this is a complex question which requires a complex answer" or simply "the way blades work is through the application of moderate pressure over a very tiny area (the edge) which causes massive levels of force to occur at the edge which we perceive as 'cutting' when the blade is applied to a substrate. It's less of a chemistry question and much more physics.
Think about it this way- even with super fine 0.05 micron (50 nanometer) alumina abrasive used to obtain that 'perfect edge' the reality is there are still very small scratches present everywhere. From this wikipedia entry you can see that the covalent radius of an iron atom is 140 pm (picometers) or 280 pm for the diameter. Meaning, a perfect 50 nm wide scratch in your blade (which to our eyes appears as a flawless mirror polish) could still house ~180 iron atoms in a line side-by-side across the scratch. So even our craziest abrasives cannot produce anywhere near an "atomic" or "molecular" edge.
Furthermore, the discussion on the "touching of atoms" is flawed since there has been no agreed upon understanding of what an atom is or what constitutes them touching. The electron cloud surrounds the nucleus and both are part of the atom as a whole. Not to mention the weirdness of quantum mechanics: while the electron cloud density is highest near the nucleus, that density also tapers off into infinity as you move away from the atom. So when do they truly begin to "touch" or how much perturbation to the electron cloud constitutes "touching"? It goes even deeper but ultimately, it doesn't matter for the blades we use.
Overall, while the chemistry of the blade steel is very important for determining its properties and potential, the discussion of cutting with "normal knives" has more to do with elementary physics (force over area) than any kind of "stiction" or intermolecular forces that may occur between the knife edge and the substrate being cut. [Note: 'stiction' may be one reasons why convex edges cut better than flat bevel edges, but I'll leave that for a different discussion].
Anyways, I'm here for future questions if this thread doesn't get locked.
/working on a PhD in Materials Inorganic Chemistry
Interactions between solids is PhD level stuff.
If you really want to pursue this, get a PhD in Physical Chemistry. It's that complex.
Because electrons alone are not what is holding the material together. You are actually dealing with molecular bonds between atoms. So you need to look at bond strengths. Metal cuts plastic because the metal is a crystal structure, while plastics are covalent bonds. The bond strengths in a crystal structure are greater than those of the covalently bonded plastic.
This bears mentioning. Many times folks will immediately turn on you if they see a lack of experience or even if they sense less than their own. They will fall back on humor or even ridicule. Don't let it get to you as normally it's only a sign of a lack of understanding of the subject or the lack of something valid to say. You'll see all sides in this thread. I notice the note with your edit, again don't join that fray. Remain above it. Your observation was excellent. You applied what you learned to a real world practical application and I, for one, applaud your effort. The application of what you learn in school is, IMHO, far more important even than what you actually learn.Polished vs. Toothy
Sorry guys, Been having a bad day today. I'm calm now. But back to the subject. I'm trying to say that the electrons on the edge are repelling the electrons on the material resulting in a cut. If this isn't the case please tell me in a serious manner why it isn't correct.
You know, Ditch Digger, it's funny. None of the powers that be here think the OP is a jerk because of this post. Sure, everybody had a good chuckle, but that's different.
You, however, are cleanly on everybody's radar, and would be well advised to just STFU. Now.
