Looking at the photo I would suggest a couple of things:
It looks like it was worked too cold and the wrong hammer face was used.
Work your steel
hot. carbon steel will move under the hammer better if it is in the plastic stage between 1700 and 2000F. Quit hammering when the color loses the red glow (black heat). Work it evenly, a few blows on one side..a few on the other. Get/make a drawing hammer to draw out the tang (and any stock that needs to be thinned/stretched). You make one by taking a blacksmiths hammer (HF cheapie will do fine) and grind the vertical peen to a 3/8 round radius at the edge. You strike the
hot steel straight down with this and it pushes the steel away in both directions. A few firm blows on each side, a few flattening blows with the regular face (with the tang laid flat on the anvil) to straighten it back up a bit....re-heat...repeat. It will draw out the steel fairly quickly. Once it is drawn out, then you can clean up the shape nicely with the regular face.
I must admit that I often cut the basic tang shape into the bar
after forging the blade.The band saw makes this job about 60 seconds long. Then I can just grind in the final shape...or forge it to final shape if it needs tapers and curves.
Another thing that the photo shows is that you didn't curve the blade downward before you started forging the bevels. After forging the basic profile of the blade, put the hot blade on the bick (horn part of the anvil) and curve it
down like a banana. Then forge in the bevels. The blade will lift and straighten as you forge. You may even need to curve it down again when partly forged if the tip rises too far. Again, done at full forging heat, the steel will curve like play-doh. Done too cold and it will bend into strange shapes.
A set of box jaw U-tongs (my favorite) will help a lot,too. See Tom Clark'sTom Tongs and tools at:
http://ozarkschool.com/
I forge 90% of my blades with U-box tongs. I would suggest a pair of 1/4" X1" box jaw -U tongs and a pair of 1/4" X 1.5" box jaw -U tongs.
Stacy
