Re the main power switch
I used a toggle switch
You could use a SPST switch, but in case the live/neutral lines are reversed on an outlet , and in general I just over build things, I used a DPST and switched both lines.
http://www.gardnerbender.com/pdf/products/Switches.pdf
Both rated at 1.5 HP which is the motor rating, if you had 2 HP motor ,you would base the switch on that.
GSW-14 is what I used
GSW10 would also work.
GSW20 is the boot cover – probably not available at the stores listed above, but automotive parts suppliers tend to stock them.
I was able to buy it locally at HomeDepot / Lowes / Home Hadware /
Canadian tire also lists it, and youcan check inventory online by selecting your local store
http://www.canadiantire.ca/AST/brows....jsp?locale=en
I used crimp on eyes to attach the wires to.
The Count,
In one of your other posts and this one you mention to get a toggle switch rated for 2hp if you have a 2hp motor:
Do they sell 2hp rated toggles? will GSW-14 work on mine if I'm running a 2hp motor but will be using 110ac which will reduce it to 1.5hp(according to the forums)? I didn't find anything that was rated for 2hp the gardnerbender or homedepot website..
Work, this may be way off but here is what I use to toggle back and forth from one machine to another and another switch like this one to turn the main power off.
http://www.mouser.com/ProductDetail...MVr50lLt2tQWy0EXBsHPMvnxiEwxw%2bbdAUSTBTskQ==
Can you describe your setup, it sounds like something I would like to do. Thanks.
PT Doc, I use the exact set up as Silver_Pilate. Check out his thread: http://www.bladeforums.com/forums/showthread.php/608477-KMG-pics-and-video!!/page2?highlight=Mouser
Thanks. I remember that thread. No issues with the setup I guess?
