- Dec 27, 2007
And off we gol on oil . . . .
We’re just trying to help prove your point… I thought this is what you wanted.?.?And off we gol on oil . . . .
By .01 mpg at the expense of burning more oil and creating other problems.better mileage results in tests........
Sadly my white runner just got destroyed a couple days ago by a drunk driver. It did it's job, and saved my daughter from any injury.This is my first. My wife grew up with Toyotas and she likes them, but she drives a GMC currently. I picked up the Tacoma in November 2021 since they were the only brand not being marked up by the dealer locally. It’s a good truck, definitely different from the Chevys and GMCs I grew up driving.
A man of taste hereSadly my white runner just got destroyed a couple days ago by a drunk driver. It did it's job, and saved my daughter from any injury.
Great rigs.
View attachment 2107034View attachment 2107026View attachment 2107036View attachment 2107024
My father owned a garage for over 60 years, I've seen and worked on lots of cars. Many years ago engines would typically last 80k to 100k miles before they needed a rebuild. A rare engine might go 150k. This was in the era where it was common to run just 30 weight oil, then a little while later multi viscosity oils were more common. Oils and additives have improved over the years, but more improvement is possible. Now engines can go twice as far without a rebuild, and twice as long without an oil change. Besides oil I don't know what else has changed. I think engine block materials, crankshafts, bearing materials are the same. Maybe ring materials have improved.Once you open up the journal clearances you get more slop. More slop means the shaft is kind of bouncing around inside, not good for durability. Proper oil with tight tolerances can provide very good wear characteristics. I've seen some of these "new motors" from Mazda with 250k+ on them that are still running fine.....
