There was a "Rambling Rifle" I found on a web sight a few years ago. It was designed by a backpacker for a quick change barrel system so he could have multiple cal. with the same gun. I want to say it was built off a Winchester '70 action but I may be wrong about that.
H-S Precision makes a take down bolt gun.
http://www.hsprecision.com/new_take_down.htm
Z hat custom has these.
http://www.z-hat.com/takedown.htm
Winchester made most of there lever guns in a take down version. The last production model was the '86. (imported threw Miroku) You see them on the gun auction sights from time to time.
Most of the factory/custom take downs are pretty pricey.
Most bolt or lever guns can be made into a take down with a little for thought and basic shop skills if you do that sort of thing. I did it to a Win. '94 just to see if I could and it worked out nice. You need a Lathe, not a Dremel tool project. A bolt action would be easer. IMHO.
The jam nut design of the Savage bolt guns would be easy to break down in the field with a spanner wrench and a head gage. Shorten the forearm and you could make a real nice small package. The same locking nut would work on any bolt gun with the action lug build to the action . (Non Remington 700)
Several Mil. Spec. models would fill your bill if you don't mind the Military look. The Ar- 10, Fn-Fal come to mind since there designed in upper and lower parts. Pop the pins and go. The Fn can be built a lot lighter than the Mil. Spec. guns with the right parts.
