Very, very good! I've been forging indoors so I could see the color.
Yes, from what you say I have been getting the metal too hot. Thanks very much, everybody!
Andy
Indoors is good, also try to maintain a consistent level of light from day to day. Most of the steel I have seen that looked like your image was forged or heated outside or with sunlight shining directly on the work place. This is why I detest it when books or sources use colors to describe temperature... "cherry red?" In whose shop??
That being said lets try. One should practice heating a bar of steel from one end in the dimly lit room you will work in and observe the color shift Don referred to. As the piece reaches critical it will begin an endothermic transformation (meaning it will get very hungry for heat and light energy), this will be very evident in a shadow or dimmer area in the steel. The steel will grow no brighter until the transformation is complete. Find that area on the heated side where the steel first gets brighter- that is critical temperature for that steel!:thumbup: learn it, live it! Contrary to the bilge we have all heard, the magnet will lie to us, that color cannot lie to us about the transformation since it
is the transformation. When you learn this color you will be surprised at how much cooler it is for many alloys that what you thought it was.
In subdued lighting Yellow is only good for the very initial heavy forging operations and most hammering can be done in orange. Segregation is an every increasing issue that I am seeing in steel straight form the mill theses days, and this is one situation where forging
does have the possibility of improving the steel, but only if you get it hot enough to move that stuff around, this obsession that bladesmiths have with low temperature forging only increases segregation. At the beginning
get it hot and move that stuff around (both outside and inside) then drop down to normal austenitizing temperatures (around 1500F) for the lighter shaping. The last couple of heats can be sub-critical so that you can straighten and smooth out the piece without dinging it up badly, but be aware that the more you mess around in the 1300-1350F range, the more segregation will occur.
"grain size", "grain size", "grain size" (ad nauseum)...:jerkit: Bladesmiths have a morbid unhealthy obsession with grain size, yes smaller is good, but grain size is one of the quickest and easiest fixes a smith can do. In just a couple of heats (if done right) any grain size can be corrected, not so with carbide segregation, and if the carbides pool in the wrong spots they will make changing the grain size problematic. The problem is that fractured grain size is the only thing that 98% of all smiths can see so they focus on it; carbides have much more power to make or break a knife but "out of site, out of mind."
The same for normalizing get it hot the first heat and "normalize" things. Get everything evenly distributed and the grains equal in size, forget about what size it is for now as long as it is the same. On the next heats go for bright red where the magnet just stops sticking. Do it a couple of times allowing the piece to cool to at least around 700F (depending upon the alloy) before reheating. After the second or third heat you can throw a quench in there if you like, the added strain of martensite will eliminate around two cycles of air cooling in reducing grain size, just be certain you have reduced the grain to a reasonable level with gentler cools first since quenching large grain could result in cracking.
For annealing, the old stuff-it-in-the-forge thing may be alright for steel with less than .8% carbon, as long as you let the forge drop to "cherry red first” but it may be better to heat the blade to slightly non-magnetic and stuff it into wood ashes or vermiculite. For steel with over .8% carbon I am becoming much less supportive of those annealing methods as I look firsthand at the results. I would do my "multiple quenching" now and then cycle the hardened blade a few more times to dull red, never allowing the blade to go non-magnetic. Actually, no I wouldn't,
I would simply put it in my kiln and run my standard spheroidizing program and go have dinner
Forget the differing alloys; I think anyone could see why it is critical to know what steel you have since just changing the carbon levels a fraction will seriously impact how you will have to treat it. Get good steel! Take your lawnmower blades, old springs, railroad spikes; saw blades, tuna can lids, to the scrap yard so that they can turn them into good steel! Most scrap yards will even pay you for it! With enough poundage you could make enough to buy a brand new bar of steel!
