- Nov 22, 2009
I thought his test was to be able to feel your heartbeat at your finger tips when you touch the edge?
No I think you can see you heartbeat (every time the blood squirts out)
Sorry couldn't resist...
I also find that I can get a pretty good idea of the condition and sharpness of an edge just by looking at it and seeing how the light glints off the very outer most "edge" of the edge. The more glint you see at the very edge the less sharp it is. Ideally you do not want to see any glint that is separate from the rest of the edge, it should appear to be one continuous grind ending in a "zero point" looking edge. I use this method to visually inspect an edge that I am working on, sometimes there will only be one small spot along the edge that needs more work and I can spot it just by looking this way.
...Does that make sense to anyone else, or is it just me?
I use the sharpmaker, and I can get an edge that I dont even like to put my finger on and move it across the edge without any pressure. I have used this same edge to cut through a pop can over 15 different cuts in various ways and it will still shave hair and push cut paper. To me this is a usable edge and I dont really see why I would need it sharper. But then thats just me. Perhaps I need to hold a knife that will push cut toilet paper though first lol.
The three-finger test of edge sharpness is a technique pioneered and popularized by Murray Carter. In our two sharpening DVDs, the technique is demonstrated and explained in detail. Some feel, however, that this method is not as effective as claimed, that it is not possible to detect a burr or a wire edge using the technique. To set the record straight, let us fully explain to our readers the purpose and correct technique for employing the most expedient and valuable sharpness test there is -- the three-finger test of sharpness.
The foremost purpose in employing the three-finger test is to gain experience in discerning relative sharpness. We use our three fingers because:
1) they are more sensitive than the thumb;
2) it is ergonomically convenient (it feels natural);
3) unless you lose a finger or two, you will be able to use the same testing medium for the rest of your life.
We will gain experience over time by utilizing the best way to get direct feedback -- our fingers. The test is not dependent on any gadget or device enabling you to conduct it anywhere and any time you come across a blade. Again, to emphasize my point, we gain experience by doing it more often than any other test procedure.
By eventually testing hundreds of blades (and by starting with a new Carter Blade as a reference point), you will be able to easily discern not only relative sharpness, but also relative thinness in the edge as well as any defects in the edge such as micro chips, burrs or a wire edge. Additionally, there are some who fail to pick up on the equally important companion test to the three-finger test -- the Arm-Hair Shaving Test. If a blade shaves and feels scary sharp (with no edge imperfections) according to the three-finger test, then the blade is sharp. End of story. (N.B. Relative edge geometry of the primary and secondary edges is an important factor of strength but not of sharpness, and so, therefore, it is not discussed here.)
I can only conclude that if one fully understands what I have stated time and time again, has personally seen me demonstrate it to him, and has practiced the three-finger test to the point where his fingers can discern all the wonderful mysteries that can be easily discovered on a blade edge, then that person will fully appreciate my time-tested three-finger technique of testing blade sharpness.
just to put some things in perspective, not bashing anyone.
a couple years ago i was very involved in the "in the kitchen" subforum of KF, lots of great infos there regarding japanese style kitchen knives, sharpening, waterstones etc.
lots of very competents users, and a couple of sharpening "gurus" with different methods and point of view ... it was fun.
back then Mr carter was notorious for a couple of things, first for making very thin and very sharp blades, then he was also notorious for leaving some serious burrs on his blades.
a couple years ago there was a sharpening "competition" with dave martell as a judge the verdict was that Mr carter's knife was hands down the sharpest, but also that his knife had a serious wire edge that failed after some use and flopped right when dave put it on his plain leather belt (on a sander). keep in mind that an aligned wire edge can be very sharp, it'll cut your skin just like a clean edge. how could you discern the difference ?
so the 3 finger test as a way to find a wire edge , not so much imho.
Edge leading or edge trailing has little to do with burr formation, burrs are mainly influenced by grinding pressure followed by steel quality and heat treat quality.
I look at it like clay,
My thoughts and theories on the burr and its formation seem to be slightly different than most others. I don't see it as a problem but just a final stage that with proper technique can be worked past. Problem is, its not easy to do and can take more effort to learn to do it right than it does to pick up a strop and quickly finish without frustration.
Verhoevens experiments on sharpening is very good but it was a test on a limited sample. Although there were conclusive results the results were individual to the experiment at the time.
Edge leading strokes are cutting into the surface imperfections, even if only at a microscopic level.
Edge trailing strokes allow the edge to ride over microscopic imperfections in the stone.
If you can remove the burr by:
-stropping edge trailing
-stroking through wood
-then stropping with an edge trailing stroke
You may see better results than if you were sharpening with a edge leading stroke.
It's been said here before, but think of a sand box. If you stroke a knife through sand with an edge leading stroke you will dull the edge, but if you stroke the knife through sand with an edge trailing stroke you will sharpen the blade. Make sense?
I think you're over thinking it. You're all about Murray Carter's method but you're only catching a glimpse of it from the free YouTube videos, and I think it is leading to some confusion about it. I'd like to offer you a copy of the new DVD, Blade Sharpening Fundamentals, for digital download. What is your email address, HeavyHanded?
