- May 28, 2013
the bear grylls way of checking sharpness would be to shave your sack... after drinking your piss.
Interesting that this thread got revived. I just got a Spyderco Yojimbo 2 yesterday and examined the factory edge. It's got grind marks that look like ~320 grit or maybe slightly lower. It's also got the same tiny microbevel at the very edge that I was previously told is from the buffer used to remove the burr. That polished micro cuts phonebook paper rather cleanly and is overall quite sharp.
Doing the three finger test, if I use more than slightly light pressure, it does stick some, and I can see my finger pads move. But it doesn't really "feel" sticky, more like slick with a tiny bit of drag. This led me to use light pressure and the blade just slid over my finger pads, almost like a very dull knife would. I sawed back and forth 3 or 4 times (lightly) and felt no bite. Testing with my thumb pad, I felt a lot of bite, indicating a quite sharp edge. I was puzzled and felt like I'd learned nothing more about the 3 finger test. Just more data that doesn't make sense.
15 minutes later, after playing with opening and closing the knife a bunch of times, I was looking at one of my fingers that slipped off of the lock and kind of hurt. I happened to see out of the corner of my eye, my 3 finger pads I had been using. Looking closely, the middle one had a clear slice in it. Pulling it open, I could see red, but no blood came out. Then I looked at the other two. *Both* were also sliced, though not as deeply as the middle one. I laughed out loud at my ignorance and discovery.
It's been unseasonably cold here, and was probably 32F when I got home, wearing no gloves. My fingers were no where NEAR numb, but they weren't exactly warm and sensitive either. I don't know if that had anything to do with it or not, but this factory edge, which didn't feel very sticky, absolutely cut my skin. I'm still confused by this test, but I've learned a little something from my experience.
Brian.
There's nothing quite like a shorn scrotum... you should try it some time~Dr Evil
^^^^ Hence your name![]()
Brian.
