If you hit it with 400 grt and then 600 grt it should start to get smooth enough. After the 600 grt you can rub it down with 0000 steel wool. that will just about get out all the scratches and if you have a buffing wheel and some black and red compounds. you can do all the same on the aluminum as well as the phonolic handle.
the only problem with steel wool is it can leave bits inside the knife which will rust.
Never had that happen, I have used it in the final stages of cleaning up knives for years. Plausibility is there, but probability is far off...
Hi David,never seen somebody sand the handle of a 119.I guess if it can be done sooner or later someone will do it.Heat shrink can be had in that size as well. Hello, Skyhorse. DM
