I saw a TV show that was talking about swords and metal a few years ago. The host was showing that when a piece of metal is bent, it changes it in some manner. He demonstrated with a flexible piece of steel wire, and after it was bent it became much stiffer. It could not be bent back to its original shape. You may break that handle trying to bend it back to the original position.
I think the show was called Secrets of the Samurai Sword, but I am not certain. Secrets was interesting to watch anyway.
It's interesting to me how many people comment to "Suck it up" and "Buy a new knife." Although I don't think it's a failure on the Becker design, I DO think it's an opportunity to improve an existing design. EVERY failure is an opportunity to improve. Shouldn't Ka-Bar be interested in this failure? Who knows that they are and who knows how many other failures they've had similar to this one that were NOT posted on Bladeforums.com?
If Ka-Bar is interested in pleasing their customer base, one that seems to appreciate the durability of the Becker line, they need to consider every failure. Even those that come from "abuse" of the tool in question.
Survivormind
However, all is not lost, even if Kabar won't replace it. Looks like the beginning of a major mod to me.
personally, i'd probably find a safe way to chuck that up, and get a pipe, and bend it back
I found out what the issue was. When I got the blade stuck, it wouldn't go ANY further and I had to beat on the handle to work it out...
Using an axe or hatchet prevents bends as well. Who knew?
Good point! Mora's out-carve my small beckers, so why buy beckers?Just use an axe and a mora, save money too!
ah, that's clearly abuse. that's akin to clamping the knife in a vise, and trying to bend it with a pipe.
you should withdraw your warranty appeal, and do something cool with your knife, or bend it back.
I would try to bend it back. If it broke I would just call it my own bad luck....then get another. I really think it could be bent back if you went slow. Probably not good as new....but better than the way it looks now. I would build a wooden jig, 2x4 "t" post and a 10 ton hydraulic jack and push it up towards a solid object like a house beam in a garage. It would not take much to bend it.
