Bunch of silliness in here. The cutouts are there for a reason. It's more work and more expense to put them in. If they didn't need to be there for proper balance, I'd bet they wouldn't be. And the other methods of doing things take a lot of work (tapered tangs, for instance).
Most companies don't warranty batoning, and it was clearly done wrong with a blade that size. I've never seen the point. Batoning breaks more knives than virtually anything else, for precisely this sort of reason. If you get hung up, DONT KEEP BEATING ON IT.
Now, I'll grant MM that he may not want to use an axe after what happened to him the last time he used an axe.
But still, those of you thinking that Ka-bar clearly should replace it because of an instance of user abuse, which action they explicitly state they do not warranty, would do well to rethink your position. We love Ka-bar because they actually MIGHT replace the knife, despite the fact that it is CLEARLY out of warranty. But we see too many people taking advantage of their generosity, and that policy might well change. You're not just abusing the knife. When you submit a warranty claim for something that you did that voids the warranty as stated, you're abusing the good will of a good company as well.
The above isn't directed at Mountainmist. He only asked for advice, and got a lot of varied advice. But for those of you thinking it's foolish of the rest of us to think that Ka-bar shouldn't have to warranty something they specifically say they don't warranty, I just don't see how that makes any sense at all.
I also wouldn't try to bend it back. The strength of the steel comes from the alignment of the crystals within the steel. When you bend it, you introduce gaps and weakness within that structure, because you're displacing the structure. If you're going to bend it back, you need to manage the metallurgy as well (basically, you'd need to have it at the tempering temp). Simply bending it back cold will just further stress the metal in the opposite direction, and may make it more likely to fail catastrophically. By way of practical example, try bending a paperclip back and forth. After a while, it breaks. Why? Because you've displaced the crystal matrix to the point at which it's not connected. Bending things with repeated, forceful impacts only widens the gaps even more. If you are going to try to bend it back, make sure you get the tempering temp from Ka-bar, and heat the blade up in your oven to that point. Try to use something that will generate steady pressure (like clamping) rather than a hammer.
I do think you've got something ripe for an interesting mod, and I'll be interested to see what comes out of this. Do be careful with your batoning, especially with this blade, in future. When it binds, don't power through it, or you may well end up with a catastrophic failure, which for the accident-prone, might result in serious injury or death.
