Josh Rider
Stuff maker
- Sep 2, 2014
Will your knife tip end up being too thin/pointy/delicate?
I concur with the others. I might also rotate the angle of the butt clockwise a bit making it closer to a 45˚ angle. Keep an eye on the guard lug thickness. I like the design but try to make them the same thickness and taper. The top lug looks good.
^^^^^ I would take this guts advice. His Bowles are very esthetically pleasing and look like they would fit the hand perfectly. :thumbup:
I really appreciate all the input. Never having done a Bowie or hidden tang for that matter is why I wanted advice. I always try to make my fixed blades flow from tip to butt so missing that on the Bowie I drew came as an aha moment. I also would like to keep it thin at the tip. I'll be using either 3/16" or 1/4" depending on whatever I feel like at the time as I've ordered both thicknesses in 1075 and W2 from Aldo. I'll be doing a hamon as well. If the tip ends up being too small with the clip I'll grind it back some.
The design looks great.
However, I recommend you to have a look on some commercial Bowie Knives from: http://huntinguides.com/best-bowie-knives/
