Chemistguy
Please read some of the stickies and previous threads about 1084 HT.
Canola oil is fine for your quenchant. Vitamin E is for rubbing on stretch marks on old ladies butts and thighs, and something that health food stores make money on by telling you that you need it ( which is 99% baloney)....but not for quenching steel. The theory that it will retard oxidation in the oil because it is an anti-oxidant is just plain foolishness. In a few years you may take organic chemistry and cellular biology, and understand the difference. What vitamin E can do for you is greatly increase your chances of bleeding and hemorrhagic stroke.
To do the HT on your 1084 steel you heat it to 1650°F and cool to black, then dunk in water to cool to room temp. Then you heat it to dull red, and still magnetic, cool to black and dunk in water again. These steps are called normalization. They remove stresses and get the steel ready to harden.
Next you heat it to 1475-1500°F, and hold long enough for the entire blade to equalize in temperature and color ( I doubt you can hold it at an even temp for 10 minutes in your coal forge, and that is not needed for 1084), and quench in 120-130°F canola oil. You want the metal can filled with the oil to be 4" deeper than the blade and at about 5" wide. A paint can will work well for smaller knives, but something taller is a better choice for a 10" long knife. You need the whole knife to go under the oil. DO NOT just quench the blade part only or you will have a flare-up ( as well as inviting other problems). For a 10" knife you may need three gallons of oil. Can you use less .... sure .... will it harden the knife as well....NO.
Finally,
Don't try and put an unusual or complex explanation to simple things. This is called the Law of Parsimony ( Ockham's razor). The red stuff isn't some dangerous mercuric oxide...it is iron oxide, AKA red oxide...AKA rouge. Nothing complex about how it got there or why it is red. When you heated the spike red hot, the iron in the metal ( probably about 99.2% iron) reacted with the elemental oxygen in the air. That reaction Fe+O:O ( atmospheric oxygen) = FeO2 . Upon dunking in water to cool it off ( I suspect you did this) some of the iron oxide dissolved into the hot water film on the surface and then crystalized on the spike as red iron oxide as the water evaporated. The structure and arrangement of the atoms in those crystals absorb all light in the 650nm range, thus it appears red to your eye.
Just a straight forward question...no insinuation...How old are you, and what level of chemistry study are you at?
"Pluralitas non est ponenda sine neccesitate"
"Frustra fit per plura quod potest fieri per pauciora"
"Entia non sunt multiplicanda praeter necessitatem"
