- Feb 27, 2006
idkx, i found it faster to do the profiles with a 36 grit 3m 984f than with a band saw. experiment with different stuff. profiling a medium sized blade, my arms are killin me afterwards lol.
Why you need oversized hole ?When it comes to drilling those pin hole in the handle, do NOT use a 1/8 inch drill (looks like you are shooting for 1/8? They need to be slightly oversized.(don’t ask me how I found this out...). Go to a drill size chart, and use a drill one step larger than your pin
(Example - if your pin is 1/8, drill the holes with a #30 drill bit)
Leave little room for final grinding/shape plunge ..Don t grind them from start where you want them to be .......I will check those out! My hands feel beat up today.
Because the pins vary slightly in size, and can end up binding in the hole. One step up gives enough leeway to avoid an interference fit, still is tight enough, and leaves a little room for glueWhy you need oversized hole ?
That is likely part of it. I have also seen these tight interferences in holes drilled in hard wood ... and have also measured a range of rod stock from different sources ... and they do vary in actual diameter. All it takes is a slightly undersized drill, and a slightly oversized rod and, whammo...It has been my experience that an accurately sized hole is somewhat undersized after heat treat and needs reaming or chasing due the the metal expanding.
Sometimes I m lost with your USA 3/4 and 155/67 measurement ......It has been my experience that an accurately sized hole is somewhat undersized after heat treat and needs reaming or chasing due the the metal expanding.
I have several times drilled before heat treat, and the holes that came back were no problem ... and that is MUCH easier than trying to enlarge a hole after heat treat.I have not tried a one size larger letter drill as of yet. So, I don’t know if that will give the clearance I want after heat treating. And the blade is so hard that it ruins a bit because the bit only touches on the very sides of the tip.
I do want my pins or Corby’s to have a snug fit, they are pretty consistently sized. At least the ones I have are. I can always sand the pin materials if needed, but sanding the corby’s are a pain. I usually end up taking too much off or having to go back and forth to the grinder, etc.
Now for resizing 1/8 inch holes I use a solid carbide burr in a Dremel. Works good for that size. Haven’t found larger sizes with the shaft size needed for the dremel yet.
Just a cheap dust mask I had. Before we moved I had to remove and replace the insulation in the crawl space of our old house, I had 1 left over from that.
Gonna get one of the 3M actual respirators if those are good?
Yes - a # 12.Just checked, the rod I got for the pins is... 3/16 x5"(brass).. sooo if I'm looking at this chart that would be a.... 12?
