actually, just looked. #12 seems hard to find. #11 is seems more common and available....Just checked, the rod I got for the pins is... 3/16 x5"(brass).. sooo if I'm looking at this chart that would be a.... 12?
I did when I originally drilled them....You may have to run the bit through the scale's holes a few times - sort of honing them out. It works for me.
Looks like it will take until friday to get #11 bits in. Looks like I will be sanding down the rod.... :-(Just checked, the rod I got for the pins is... 3/16 x5"(brass).. sooo if I'm looking at this chart that would be a.... 12?
Sometimes I m lost with your USA 3/4 and 155/67 measurement ......and use a drill one step larger than your pin ,if your pin is 1/8, drill the holes with a #30 drill bit...confused me for moment .
3mm is 3mm and next one is 4mm in my world ...................All between is special one . ......like 3.1mm , 3.2mm etc.
Hah ... you are looking for logic and rationality in the non metric system? The full stops (1/8, 3/16, etc) only exist because they can be defined as the ratio of two integers - not because there is something existentially good about those particular diameters - there is no other rationality behind it (in the metric system, everything is defined by rational internal relationships - even down to defining the dimensions of sheets of paper)..This numbered drill bit system is weird. Why are there only three steps between 3/64 and 1/16, or 1/8 and 9/64, but six steps between 5/64 and 3/32?
I see this immediately after drilling also. I also see it with holes drilled in steel.C Cushing H. When you drill wood, the fibers compress, then after you finish drilling they expand. Coming back hours/days later the hole will often be smaller than it was originally.
Try drilling them again and immediately try your pins.
